08-03-2018, 07:06 PM
2019 28' International
Murphy
First trip. Going great except....
Well we made it to the site and most things are working great. Except....
Fridge is not cooling tried electric and propane.
The water doesn't come on in kitchen sink. Tried city hook up with and without pump. Looked and the two halves under sink are open.
Can't get the Polk system to sync.
Other than that all is geat
08-03-2018, 08:24 PM
2017 30' International
Charlotte
, North Carolina
Fridge takes several hours to get cold. Google your Polk owner's manual to sync, or dig manuals out of your Airstream owner's bag.
Not sure about the faucet. Getting water other places?
08-03-2018, 09:47 PM
2017 25' Flying Cloud
Waco
Check the fridge breaker just to be safe. But after initial hookup, typically you must wait about 8 hours or so to cool down to 40F. Eventually you get accustomed to the normal Dometic fridge cooling cycle times. Its just not fast like the home kitchen fridge.
Also, some like to keep their fridge running on propane during short drives between campgrounds, because of the rather long cooling cycle time.
When you do park overnite, Always remember to level your Airstream, to insure proper operation of the Dometic fridge. Damage could result if its operating, and your trailer is not level. I keep a circular bubble level in a galley drawer for checking if fridge is level.
08-03-2018, 10:46 PM
2019 19' Flying Cloud
Renville
In my old trailer, water flow from faucets stopped when the screen at the faucet outlet clogged. I would remove the screen, clean it and flow was restored.
I currently camp in a 19’ Flying Cloud towed by a Nissan Frontier.
08-04-2018, 06:53 AM
Murphy
I am getting water in bathroom and shower but not at kitchen
08-04-2018, 08:01 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Do you have water at the outside shower if equipped? Our 11 the water gos from the bath sink to the OD shower to the K sink and no valves at any of those fixtures.
As said for the refer it takes time, we start ours a day before a trip.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
08-04-2018, 08:21 AM
2018 28' Tommy Bahama
atlanta
, GA
for the Polk audio, Check and make sure your blue tooth is on, Start scanning blue tooth on your phone, press the center volume knob and hold for about 3 seconds. It will show connecting bluetooth. Should connect right up. Enjoy your music..
2015 ford F 350
2018 Tommy Bahama 27FB
follow us on RVHive.com
08-04-2018, 08:23 AM
atlanta
, GA
For the kitchen sink, it sounds like the valves under the sink (crecent shaped knobs) might be off. The ovals should be in line with the hose. if it is cross ways, it is off.
2015 ford F 350
08-04-2018, 08:35 AM
Waco
Alin Cal is correct. If you have water to outside shower connection; then you must have water to your kitchen sink. You may have air in the pipes from factory install, if so.....then opening water from your lowest drain point clears the system. Kitchen sink will have shutoff valve. ...which must be opened.
08-04-2018, 09:32 AM
2018 25' International
Columbia
, Missouri
I had the same issue with the sink, it was a clogged strainer also in a relatively new unit. Are you getting a flame in the fridge on LP or are you getting the LP error light? I was getting the error very frequently, my propane valve at the fridge needed a very small adjustment and now lights on the first spark every time.
08-04-2018, 09:50 AM
2014 30' International
DFW Airport
In Summer my Dometic 2 way fridge takes 24 hrs to get down from 90 to 39 deg F. 12 hours if I help it with ice, and interior as well as external fans.
08-04-2018, 09:54 AM
Murphy
Originally Posted by Martee
Alin Cal is correct. If you have water to outside shower connection; then you must have water to your kitchen sink. You may have air in the pipes from factory install, if so.....then opening water from your lowest drain point clears the system. Kitchen sink will have shutoff valve. ...which must be opened. Attachment 318850
We let the water run on outside shower and that seems to have fixed the sink problem. Thanks much
08-04-2018, 12:16 PM
1975 27' Overlander
Galena
The frig problem. Like all others say, it takes a day to get cold on it's own, If your frig is stuffed with goodies you can buy a little interior frig fan with 1- D volt battery. It really helps, and assists with the loss of temp during openings. If not, know that the cold air comes from the freezer and blows down to the refrigerated section. You may be blocking the entrance vent of the cold air by overloading food in that area. Sometimes this area can be blocked with an ice build up at the opening which must be cleaned off before it will refrigerate properly. This is one reason people let their frig run for a day before loading it. If you continue to have problems and can't resolve it, make sure you use a thermometer on the food you take out of it. Food poisoning can end a good time real fast. Good luck, safe travels.
08-04-2018, 04:18 PM
2015 28' Flying Cloud
west rutland
, Vermont
I have a problem keeping my trig cold on gas! Works great plugged in! Help
08-04-2018, 04:49 PM
Murphy
Got it to work. Thanks
08-05-2018, 03:46 PM
2006 19' Safari SE
Tucson
Been watching this thread as a general IFM (Information for Me)...
Yay for getting it working! Once again, a demonstration of folks on the Airforums willing to help and throw out suggestions until the nail is hit on the head. It happens over and over here. Good group.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
08-12-2018, 10:36 AM
Fayetteville
For your dramatic refrigerator something you want to do after it has been stored for any time is to make sure both of your LP gas bottles are open. Then go inside and try light your burners on the stove. This may take a few attempts but insures gas is actually flowing into the trailer. Once that happens you should have gas for your refrigerator to light. I’ve had that occur a few times. Usually it’s something simple but if not, see the dealer.
08-12-2018, 03:58 PM
2019 27' Globetrotter
McHenry
Fridge suggestion - worked for me
We have a 2018 Flying Cloud 23FB and the fridge would run but not get cold on either electric or propane. Read the manual and it said the trailer must be level (mine was parked in the driveway). Once I leveled the trailer the fridge worked perfectly. Just a thought...
08-13-2018, 07:36 AM
2004 30' Classic Slideout
Ft. Myers
Cold reefer
To get your reefer going faster we use a small 110v clamp on fan blowing up the coils in the back, and put a frozen blue ice pack with one of those little battery operated fridge fans inside. After about 8 hrs you should have a pretty darn cold reefer. We use that outside fan every time We camp,especially if the sun is shining on that side of the coach with no wind. There is a 12 volt fan kit you can get for the reefer coils but I forget who makes it. I'm sure someone on the forums knows.
S/OS #045 2006 GMC Sierra 2500 Duramax w/ Hensley Hitch, 15" GY Endurances and Tire Minders
--Mark and June-- "Every time I feel the urge to exercise, I go lay down until it passes." Mark Twain
08-13-2018, 05:36 PM
2017 23' International
Surrey
, British Columbia
checking fuses on Dometic fridge
Our 2-way fridge seems unusually slow to cool on AC (although the rear top of the unit is hot). I would like to check the fuses, and wanted any advice to confirm that checking fuses is as simple as it says in the manual: disconnect AC and remove power cable from fridge rear....then open the fuse/control box to check fuses.
Thanx for any thoughts.
