06-15-2019, 05:32 AM
2018 27' Tommy Bahama
Bainbridge Island
Box sticking out into wardrobe
Our 2018 Tommy Bahama 27 trailer has this box in the wardrobe. I think maybe the flying clouds or international 27 FB may be the same.
I wondered, why is it there? It makes almost 4 inches of the wardrobe unusable for clothes.
I took it off and it is an access panel for the shower fixture. Thing is, the box is 3 or 4 inches deep, like the plumbing sticks out into th closet, but it’s actually flush with the closet wall.
So I removed the box and replaced it with a Masonite panel sprayed white. Voila! Wardrobe is effectively 4 inches wider!
Pics to follow
06-15-2019, 08:23 AM
Marana
Can’t wait to see the pictures... but wondering why it was manufactured this way?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
06-15-2019, 10:14 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
That's CRAZY! I can't believe how many they assemble that way, and nobody in the design department thinks, why are we doing this? Your method would even be cheaper to build, which you'd think would have gotten someone's attention. What a headscratcher. Anyway...great discover, and solution!
06-16-2019, 08:07 AM
Marana
There has got to be a reason.
The pex also touches the board that makes up the closet wall, that is a spot I have quieted down with parts of swimming noodles, but from the bottom up. Forgot this access was even there...
AirstreamInc, can someone comment on this?
06-16-2019, 11:00 AM
2019 25' Flying Cloud
Tacoma
No longer there in 2019 models
Just purchased a 2019 Flying Cloud 25FB and they must have figured it out. My closet panel is just a piece of 3/4” board similar to the rest of the walls.
06-16-2019, 01:42 PM
Sag Harbor
, New York
Wow . . . hard to believe how Airstream keeps demonstrating its dysfunctionality!
06-16-2019, 01:48 PM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
Our 2015 27’ Eddie Bauer with the same floorplan/layout has just a simple 3/4” white panel. Very strange.
06-19-2019, 12:21 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Yes my 2012 was that way too. I replaced it with a piece of 1/8 inch masonite. Weighed 2 lbs. Less and let me fit in 2 bins I bought at the Container Store.
06-19-2019, 12:58 PM
2016 27' International
Sherwood Park
, Alberta
Our 2016 27FB Serenity is the same, flat, white panel, no box. Mmmm?
06-20-2019, 08:45 AM
Marana
Plan on doing the mod this weekend to remove the mystery box.
06-23-2019, 05:33 PM
Marana
First I took the mystery box off.....
...and took the opportunity to quiet up the pex plumbing with some thin felt circles. THAT’S where the banging noise was coming from when using the water pump! Very quiet now.
Replaced the box with a custom peice of painted particle board. Use the old mystery box and copy the hole pattern to reuse the same holes in the wall. Routered the edges and sanded so it should not catch on any clothing. I also put some felt strips around the edges to keep it just slightly raised and away from the plumbing when installed.
06-23-2019, 06:25 PM
The Aluminum Tent 3
Park City
, Utah
Nice job. Interesting about the banging pipes. I have that on my 23, but unfortunately in the shower walls or floor. And not from using the shower, just from the pump being on, period. Can't get to them to isolate like you did. I am going to install an accumulation tank at my pump, I've heard that can make a big difference. Won't be fun to squeeze it in to that space, either.
06-23-2019, 09:12 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Why not use a piece of lexan for the cover so you could monitor for leaks without having to remove.
06-24-2019, 07:49 AM
Marana
Interesting idea. I had all the materials already and it’s very simple to remove. Also we will know if there are any leaks as there is an access panel just below and to the left of the shower.
This way it blends in and after a while we won’t even notice it.
06-25-2019, 05:46 AM
2017 27' International
Orland Park
This is what we did. Stock cabinets from Home Depot left enough space between the shower mixer and the wall. Still 4 screws to remove.
Mark
06-30-2019, 10:34 AM
2016 28' Flying Cloud
Glen Rose
My 2016 FC RB doesn't have the protruding "box" either - just a flush panel that covers the access.
06-30-2019, 12:41 PM
TetonStreamer
2021 27' Flying Cloud
Delaplane
, Virginia
PCSkier, read your post and thought I would share with you the outcome of installing an accumulator in my 2017 23FB to cut down on pipe noise. I did the same think on my 2010 20' FC Bambi and it worked perfectly. I tried it on my 2017 23FB and the water pressure went pear shaped... anemic pressures. When I called JC they informed that in the Bambi they installed pressure cut off pumps and in the 23FB they had installed variable speed pumps (speed of pump reacts to pressure needed versus demand pump on 100% until pressure reached). Took out the accumulator tank and pressures were back to norm... noise still present.
FYI
Teton Streamer - in The Toaster
Wilson, WY 83014
07-02-2019, 10:07 AM
Bandon
, Oregon
The story behind that box....
Because I also was curious about an extension that seemed to serve no purpose, I called customer service at the Mothership in Ohio. The rep said that on some models there are switches on the back side (outer wall side) of that box (I didn't ask what the switches were for), and the box has the wiring to those switches. The switches can't be seen when standing at the closet door. He said that as long as I don't feel any switches, and therefore there should be no wiring inside, then there's no engineering reason preventing removal of that box and replacing it with a flat cover over the plumbing (as some on the thread have already done).
One would think they'd manufacture a flat cover for those models without the switching/wiring, and include that specification as part of the manufacturing process for those models. Seems like the priority was to save a few bucks on standardizing a part for a certain number of models, versus have a different part (the flat cover) for a small number of models that would prioritize closet space and, by extension, customer satisfaction...
Thanks very much to pwlldvd for the original post and to others on this thread who shared their modifications. We intend to replace our box with a flat cover, and maybe those Home Depot shelves, in order to maximize closet space.
Rick
Rick
2018 Tommy Bahama 27’
2008 Chevy 2500HD
09-03-2019, 05:53 PM
Bandon
, Oregon
Update: After removing the cover, here's what I have (see pix). The plumbing actually sticks out beyond the plane of the wall, and I don't see any obvious way to fix that. Pushing on any part of it doesn't reveal hardly any "give". Even if I tried planing the right edge of the opening to enable the red plastic plumbing to better fit inside, no guarantee that it would do that, and it wouldn't change the orientation of the main middle section that includes metal attached directly to the backside of the shower fixture. That entire middle section breaks the inside plane of the wall by about an inch, and it's not moving. Don't know why some others have apparently more flush plumbing in their closet holes - did their showers get secured an inch farther away? Don't see how that's possible, given the close tolerances on everything else that the shower contacts - walls, doors, ceiling, floor - everything has to align to a template.
I'm going to see if I can find a shallow plastic container of some kind that will fit over the hole, but still provides about 2 inches of depth. Would still gain a little space on that side - the OEM box is a good 4" deep.
Rick
2008 Chevy 2500HD
