Old 05-16-2019, 01:02 PM   #1
Silver Spud
mtpeeps's Avatar
2019 27' Globetrotter
Island Park , Idaho
Thermostat questions
We have a 2019 Globetrotter & are wondering how to turn the thermostat OFF Auto? We used our A/C for the first time (we've only had it a month!) and as I've read on other threads, our A/C would come on to cool down, then furnace would come on to warm up....
mtpeeps is offline   Reply With Quote
Old 05-16-2019, 05:50 PM   #2
Phoenix , Arizona
Press the mode button. It will cycle through the options. If I know itís hot out I hit mode button until it says A/C. At night if chilly, I move it to HP.
I donít use the Auto mode.
PhxTrotter is offline   Reply With Quote
Old 05-18-2019, 06:50 AM   #3
SewStream's Avatar
Sanford , Arizona
@mtpeeps - I think that our thermostats are designed to do this even when it is not set to *auto*. We have had this happen, too.
Get out your manual and check on that. This is especially true if you are in an area where temperatures fluctuate from warm during the day, and much cooler at night. Make sure that your propane is on, so that if it does get cold enough at night/day your unit can switch over to the furnace as designed. The heat pump only works to a certain outside temperature (40 degrees?) and then the unit will switch to the propane furnace.
SewStream is offline   Reply With Quote
Penguin II and CCC2 thermostat install questions Greg1410 Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-20-2019 10:37 PM
Dometic RM 100 120/propane fridge questions(thermostat setting plus fan upgrade) Jjona5 Refrigerators 15 08-04-2017 07:20 PM
Questions on thermostat and distribution box Ora Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-06-2016 09:33 AM
AC thermostat questions desertair27 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-21-2011 05:33 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
