Old 06-17-2019, 06:34 AM   #29
miller place , New York
Sink sunk
Hi all had a question for the group.We have a 2019 globetrotter we picked up in March .After a couple of trips found sink seperated from counter top.I read Lou`s repair sounded great but not sure that I should have to fix it as it is brand new.Also if I try to fix it will it void warranty on any future problems.If you did have this concern what did Airstream do to fix it and how long did it take .Thank you for your help in this matter. John Aspinall
John Aspinal is offline   Reply With Quote
Old 06-17-2019, 03:21 PM   #30
Hello just wondering how you made out with sink repair.Had same thing happen to me 2019 globetrotter. Wondering how long to fix and what they did. Thank you John Aspinall
Old 08-08-2019, 10:22 PM   #31
nryn's Avatar
2019 27' Globetrotter
Chicago area , Illinois
Sink drop: on-the-road fix
My family and I are traveling through Alaska and my GT sink dropped in transit yesterday. It was a bumpy road but not too bad (the trailer has been through worse). Thought I’d post to this thread in case this happens to someone else. I’ve renovated a few kitchens and am an avid woodworker, so while inconvenient this wasn’t a huge deal. When I entered the trailer this is what I saw:
I took out the drawers and the sink front and removed the garbage door to get a good look. After assessing the damage I took a trip to the local hardware stores here in Seward and picked up the following:
  • 4’ of 1 x 2 red oak
  • (10) 1-1/4” #8 screws
  • Construction adhesive
  • 100% silicone sealant
  • A couple of 24” grip clamps (which I used but didn’t really need)
  • A long (8”?) Philips head driver
  • A few other things that I didn’t end up needing
It’s mentioned earlier in the thread that sink retainer clips are only present on the sides of the sink. This is true and more clips certainly wouldn’t hurt, but that’s not the problem, at least on my trailer. The issue is that all of the countertop substrate that surrounds the sink are made of separate pieces (it’s the easy but lame way to make a sink cutout). This pic should make it more clear.
The wooden piece here sits under the countertop on the right side of the sink (facing the sink). It is only about 3” wide. There is a similar piece on the other side; I can’t tell if it is screwed down more securely. You can also see that I’ve disconnected the p-trap to avoid damaging the plumbing and am suspending the the sink with gaffer’s tape while I work on repositioning and reinforcing the plywood substrate that seems to be what failed.*
You can see in the picture above how this piece contributed to sink failure. Connecting the two pic above, it’s clear that the side pieces of substrate (that bear the most stress due to the clips) are affixed to the underlying cabinetry only by a thin strip of adhesive, and that’s optimistic. In retrospect I believe I removed glue from only one side of the substrate piece, suggesting that it was only glued to the countertop and not to the cabinet, but I can’t remember for sure.
I removed the old adhesive from the substrate piece, applied new construction adhesive on both sides, put the piece back and placed a heavy cargo container on top as a clamp.
But I wanted to improve the way the sink was supported rather than just reapply the adhesive. So I added some pieces of red oak, screwing them into the cabinetry between the clips, and screwing up from the bottom to secure the substrate.
You can also see in the pic above that while I had the sink dropped I also drilled some access holes so I could reach the screw that secures the frontmost retainer clip with a long bit (it is otherwise buried under a bunch of wood and cannot be accessed).*
Lastly, after scraping off and cleaning the sink rim and the underside of the countertop, to I applied 100% silicone adhesive around the sink instead of plumbers putty, which is what I think was used at the factory (I think this because it was very easy to remove). Under normal circumstances I would prefer the putty because it makes cleaning/removing the sink much easier. But I think the GT sink needs as much help as possible. I used some clamps and the remaining red oak strip to hold the sink in place while I secured the clips.
I reattached plumbing and didn’t put any weight in it for 24 hours. We’re just now using the sink and everything seems fine. Here’s a pic I took five minutes ago at our great waterfront campsite in Seward, AK.
Total repair time: 2 hours, not including trip to hardware store. I still consider this a temporary fix and will take it up as a warranty item when I bring it in for its first trip to JC.
nryn is offline   Reply With Quote
Old 08-09-2019, 05:43 AM   #32
jeffmc306's Avatar
McHenry , Illinois
Nryn, wow! Thanks for posting the detailed steps and photos of your "field repair". You are an inspiration to all who experience problems on the road.
I'm definitely going to take another look under the cabinet before we leave for Colorado this Monday. I hope the rest of your trip is uneventful (repair wise) but full of good times!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
2019 Ram 1500 Laramie Sport,
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 08-09-2019, 09:57 AM   #33
Denver , North Carolina
nryn,
Nice job I'll be bookmarking this post for future reference if needed. Will be reinforcing the sink soon. Thanks for the pics and description.
Dave S
link2dks is offline   Reply With Quote
Old 08-10-2019, 06:21 AM   #34
2018 27' Globetrotter
Mooresville , North Carolina
Originally Posted by link2dks View Post
nryn,
Dave S
I agree, nice job (especially on the road)! I know exactly where you are camping. Great views and a hardware store that has everything you could need as I bought a fishing rod / reel to catch salmon right outside my door.
I'm a little unsure about pic #5 with the red oak. It will probably make more sense once I take a look at my sink.
Dave, I would like to reinforce mine as well before our Fall trip. Maybe we can talk before we both tackle it. I'm hoping it can be done w/o disassembling everything.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 08-10-2019, 12:02 PM   #35
nryn's Avatar
Thanks. Do note—in order to reinforce the sink, you’ll need to drop it in order to access the cabinet sides. That shouldn’t be a big deal if you can drill the hole to access the frontmost clips as I did. If Airstream decides to redo or replace the sink or cabinetry under warranty (I had other sink/plumbing related problems—the p-trap got disconnected in transit which soaked the drawers—tighten up those fittings while you’re at it) and installs the new sink per current factory specs, I’ll be re-doing this fix and possibly adding clips. Again, not a huge deal.
Old 08-10-2019, 12:10 PM   #36
nryn's Avatar
GOUSC, I meant to post this pic to accompany #5—these are the pair of red oak pieces I used on each side of the sink. They are positioned between clips and attached to the cabinet side (you can see in pic 5) and the countertop substrate (which you can’t see) and merely provide a bit more reinforcement for the side pieces of substrate.
A piece of right-angle metal that has the proper dimensions will also work. The constraint will be the measurement between the edge of the sink lip and the side of the cabinet. I went with what I knew I could make work
Also, If I were to do this fix with a shop handy I’d probably use baltic birch plywood. I couldn’t buy plywood in anything less than a full 4x8 sheet and only have a handsaw, so I went with red oak trim, which I’m sure will be totally fine.
Old 08-10-2019, 02:53 PM   #37
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Nice job. We had the sink come apart on our classic as well. Made it to JC and they ended up removing the entire counter top and remounting as well as reinforcing everything. It feels bulletproof now.
BigSxyWhtGuy is offline   Reply With Quote
Old 08-10-2019, 05:32 PM   #38
2007 22' International CCD
Sink "unglued" from countertop while towing
Man, what a pain. I’m real glad our ‘07 International has a drop in sink in a laminate countertop...
It looks very nice now that you got it back in place!
Old 08-10-2019, 06:47 PM   #39
2019 25' Globetrotter
Montgomery , Texas
Well done y'all! Seems like there was certainly a little design defect in these sinks.
Just as an update from my original post... I've travelled over 3000 miles since fixing my sink and everything is holding up great! No issues what so ever with the VHB tape solution.
Now that doesn't mean I haven't had other issues with the rig. (like the dresser door falling off and the flooring starting to bunch up in places) But at least my fix has been rock solid
Loulou4 is offline   Reply With Quote
Old 08-11-2019, 06:27 AM   #40
Thanks for the addt'l picture. After looking a my sink yesterday, it cleared in my mind what you were doing. You also had the following note;
"A piece of right-angle metal that has the proper dimensions will also work. The constraint will be the measurement between the edge of the sink lip and the side of the cabinet. I went with what I knew I could make work"
I was hoping not to drop the sink at this time since I've been lucky enough not to have it drop. Prior to posts similar to this I've stored a 2 gallon water jug in the sink and was lucky nothing happened.
My thoughts in the meantime tie into your right-angle metal idea. I have a 2018 and the inside of the cabinet (inner shell) is a little different than yours. In your addt'l read oak picture, you seem to have a large oval opening in the cabinet side. You would then still have the exterior sides attached to that (sort of an inner shell / outershell). In mine, instead of a large opening, mine has a couple of smaller openings. In between the openings, it leaves vertical strips extending all the way down the inner shell.
I was thinking of taking 3/4" plywood and making an "L frame bracket" and using pocket screws / glue to join the bracket. I would insert a couple of these on each side between the under sink tab to support the wood strip that fails. I would screw the vertical part of the L frame to the inner shell and the horizontal piece to the wood strip that is prone to fail.
I'm thinking I should be able to access all of this by just pulling out the 2 bottom drawers.
In the instance of the 2019 GT's, I'm thinking you could add the vertical strips (3/4" or 5/8" to give a smooth joining surface) to the large opening you have in your inner shell. Just be careful the screws don't go through the laminate on the outer shell. Then attach the L bracket to that.
Equal-I-zer Hitch
"Roadrunner"
Old 08-11-2019, 10:47 AM   #41
nryn's Avatar
If I wasn’t able to wrangle the sink into position and suspend it with gaffers tape as I did, I was planning on vertical strips as you describe. I don’t think you need an l-frame bracket though, just something thick enough to reach from the cabinet side to 1/4” or more past the edge of the sink lip. But I don’t think dropping the sink (intentionally) is a big deal.
In my opinion, the factory construction technique I saw on my trailer will eventually fail on many trailers. This is not a commentary on Airstream quality—I’m not a complainer. It’s just an observation I’m passing on to other Globetrotter owners.
The technique here relies on a very secure bond between the plywood substrate and the Corian, so that the two act as one surface from which the sink could be suspended. I would have no issues with this normally, but the fact that the sink cutout is made of multiple pieces here means that they do not reinforce each other. If any of them become detached from the countertop (which is very possible given changes in temperature and humidity, and the rigors of travel) adjacent pieces will bear a lot of stress. I would hate to see this happen on someone doing dishes and who has a full sink of water, because it would likely crack the plumbing as well.
Honestly I think if the cutout was a bonafide cutout instead of an assembled one this never would have happened. But really—if the sink was going to drop at all, I’m glad it dropped the way it did. I still have 6,000 miles or more left on this trip and while not a showstopper, a broken sink would make a lot of things inconvenient. I was able to fix it on the road with some very simple tools (handsaw, drill, tape and adhesive) and though it looked gnarly, it was by no means a major construction project.
Old 08-14-2019, 02:48 PM   #42
A follow up on my post #40 regarding adding some support to prevent the sink from collapsing. I haven’t had the issue yet and did not want to drop the sink before my next trip. I agree with all that Nryn has said as to what causes the issue. The original install does not appear to be the best way to support a sink subject to road conditions, or otherwise.
I pretty much followed the process in my post. Attached are pictures of the process.
Pic #1 – The right inside of my cabinet had a ¾” recessed area. I cut a 3” wide strip of ¾” plywood to sit in the recessed area. I then put 2 pocket screws to attach it to the right side of the recessed area. I cut another 3” wide strip with a 3” X 1.5” top to it to form an “L” bracket. The top small strip was joined with wood glue and pocket screws.
Pic #2 – this shows how the pieces will lay on top of each other after installation.
Pic #3 – shows the ¾” base build up after secured with pocket screws. You’ll note there is already a 2” strip at the rear of the right side so I did not have to build up the rear support.
Pic #4 – shows the up view of the right side, front and back supports attached at the top with 2 screws thru the L bracket and into the oak support piece that is prone to falling.
Pic #5 – side view of the right side supports.
Pic #6 – side view of the left side supports. This side had a larger opening and needed a build up of ½” plywood. The support brackets were screwed into this build up piece. In the pic it looks like the left support is a little off. Didn’t notice it on the install.
Pice #7 shows the up view of the left side, front and back supports attached at the top with 2 screws thru the L bracket and into the oak support piece that is prone to falling.
I pulled out the top drawer to access the area. Used an extension to get dril bits in the top screws. I also drilled all screws in slightly to each piece before final joining. The hard part initially was getting the screw to line up with the bit using a mirror and light. After the first support, each successive one got easier.
I’m hoping this at least will prevent any failure on the road or at least get me thru a trip. If I ever have a failure then I will go the Nryn route and fix it the right way.
ID:	349393   Click image for larger version
ID:	349395   Click image for larger version
ID:	349397   Click image for larger version
Equal-I-zer Hitch
"Roadrunner"
Interior lining coming unglued? Raylo General Interior Topics 4 08-06-2013 03:13 PM
Sink / countertop for a 1978 Argosy rear bath dryenko Sinks, Showers & Toilets 1 01-19-2012 01:46 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
