Old 06-24-2019, 06:41 AM   #1
2018 27' Globetrotter
Mooresville , North Carolina
Recent Globetrotter Modifications
My wife and I are so excited about our new upgrades. A friend of ours is a master cabinet maker. We hired him to make a few modifications for us in our 27FB GT Twin Bed. He made our under bed pull out trays into full extension soft close drawers. In addition, added a door to an otherwise unusable space below the curbside bed which we will use to store our manuals. The coolest mod was that he doubled the space in our utensil drawer by adding a full sliding drawer above the current utensil tray. He also added dividers to drawer below the utensil drawer and added flip out storage under our sink. I am waiting for the tab pull to come in to replace the duct tape we have as a temporary measure. The next best part of this is that he only lives 15 minutes from us. Made it real convenient to get the job done.
Can’t wait to get back on the road to use it!
ID:	344264   Click image for larger version
ID:	344266   Click image for larger version
ID:	344268   Click image for larger version
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 06-24-2019, 06:56 AM   #2
nryn's Avatar
2019 27' Globetrotter
Chicago area , Illinois
Those are great, GOUSC. I’ve done some of the same. Didn’t occur to me to do the flip-out in front of the sink—that’s a really great idea (I have it in my kitchen at home and it’s a perfect place for sponges and stuff) so that is now on the list. I was going to do drawers under the beds and couch but ran out of time. So those are on deck for this coming winter.
FWIW, I’m documenting my Globetrotter mods in my Traveling with Tatay thread. I’m currently traveling and all of them are working out really, really well.
nryn is offline   Reply With Quote
Old 06-24-2019, 07:06 AM   #3
Just took a look at you page. You have a lot of really neat stuff going on there. I'm gonna have to find that trash can you use as the small one has really bugged us. Looks like you are handy with woodworking so it should be no problem for you to add the sliding tray to your silverware drawer. Basically notch out the back of the drawer to the depth of the upper tray you build and then add full extension slides on the side that lock when closed for travel. Doubles your space.
Equal-I-zer Hitch
"Roadrunner"
Old 06-24-2019, 05:42 PM   #4
nryn's Avatar
It’s this one in 4 gallon. Take the lid off before placing the can in the area, then put it back on afterwards.
Yep, I’ve done my own version of that. The one in your post that is now on the list is the flip-out storage in front of the sink. I’m always looking for a place to keep the dish sponge...
Old 06-24-2019, 06:53 PM   #5
Is it this trash can as I couldn't get the link you referenced to work.
Equal-I-zer Hitch
"Roadrunner"
Old 06-24-2019, 09:47 PM   #6
nryn's Avatar
Sorry. Yes, that’s the one. The photo reminds me—I also took off the handle. Get the bags too, they fit and work really well.
Old 07-08-2019, 05:25 PM   #7
jeffmc306's Avatar
McHenry , Illinois
Okay you guys are making the rest of us jealous (and the DW’s)! Super work and great ideas; thanks for sharing!
Gousc, what is the padding-like material you have on top of the beds platforms? My guess is it’s to keep the mattresses from sliding around (found ours on the floor after the last travel). I see you added plywood extensions to support the mattresses as well.
Also, you should ask your cabinet guy if he’d be interested in selling the cutlery tray setup or at least plans. I think it should be a standard factory installed feature.
You guys rock!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 1500 Laramie Sport, Blue Ox 1000# 1500#
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 07-09-2019, 07:00 AM   #8
Glad you like the work our cabinet guy did. With regard to the other items, I did add the plywood extensions per a prior post made by “Hans627”. They work great at keeping us from having the feeling we were falling off the bed. The material on top of the plywood base is called “Hydrovent”. This was a suggestion by “Kodiak2006”. Although it may help keep the mattresses in place, it’s main purpose is to allow ventilation under the mattress so that mold doesn’t develop on the bottom of the mattress since there are no box springs.
With regard to the plans for the cutlery tray setup, my friend would love to do this, and any other work similar to this you need done. However, I’m sure he doesn’t mind my sharing how it is done as there is nothing proprietary about it. He said it is a common space saving technique others have used for years. I had been in touch with Ultimate Airstreams at Alumapalooza and their trays only have access to a half tray on the top that slides back and forth. This tray gives you full access to the top and bottom so it essentially doubles your storage space. I believe you may see Ultimate Airstreams using this system in the future for their Grand Lounge cabinet storage as they were unaware of this technique. Here is how you do it;
He left the original divider in it's original location on the bottom. Lets say the rear part of the box is 5" high and the bottom storage box is 2.5" high (these are not the exact measurements but you will get the idea). He cuts the back part of the drawer down where it is 3" high. He then builds the upper storage tray to the height and depth he needs. Then he puts side full extension glides on each side of the upper storage tray. Since he now has a hole opening in the back of the drawer, this top shelf can slide all the way back when you open the drawer.
The glides also locks into a store position so it will stay in place while traveling. I think it should hold, if not, then I can add some sort of latch in addition.
We live in Mooresville, NC and our Master Cabinet Maker / friend is only about 15 minutes away from us and not far off of I-77. If you are travelling thru the area it’s a lot closer than Jackson Center, OH or Portland, OR for most of us in the Southeast. I would highly recommend him for any work such as this. His contact information is;
Marte Yerkins
704-657-6901
Marte@kitchenretrofit.com e-mail address
www.kitchenretrofit.com web site
Equal-I-zer Hitch
"Roadrunner"
Old 07-09-2019, 07:19 AM   #9
YouTube video of GT Upgrades
If this link works then it will show you the operation of all the upgrades and how they were done.
https://youtu.be/ww_fUd4ipZc
Equal-I-zer Hitch
"Roadrunner"
Old 07-10-2019, 09:23 PM   #10
jeffmc306's Avatar
McHenry , Illinois
Gousc, I can’t thank you enough for the detailed explanation of your upgrades and even sharing the video! We’re heading out to Colorado in August so I’m going to get done what I can before we go.
By the way, I couldn’t find “Hydrovent” but did find “Hypervent” :-)
Sound like good insurance to prevent mold under those expensive Tuft & Needle mattresses!
Thanks again,
Jeff & Caryle
Old 07-18-2019, 09:21 PM   #11
jeffmc306's Avatar
McHenry , Illinois
Variations of the mods + one more
I made the bed extensions and installed the Hypervent under the mattresses. While I was there I pulled the cover off the curb side bed and removed the screws holding the blank cover and installed two hinges and a latch. You can open it without a handle so it’s a “semi-secret storage” spot.
Also, the bathroom vanity mirror would pop open during travel so I removed the center latch and installed two on the left and right. You need to give it a good tug now so that should do the trick!
ID:	347016   Click image for larger version
ID:	347018   Click image for larger version
Old 07-18-2019, 10:03 PM   #12
SewStream's Avatar
Sanford , Arizona
Lovely!
SewStream is offline   Reply With Quote
Old 07-19-2019, 04:19 AM   #13
eagletoo's Avatar
2019 23' International
Long Island , New York
Jeff,
Are you concerned about covering up the ventilation holes with the Hypervent? What’s under the bed that dictates the vents?
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 07-19-2019, 06:00 AM   #14
Looks great Jeff!
I've been close to adding another latch in the bathroom but it's been behaving itself lately. If it starts acting up I'll know what to do.
I also wanted to ask what the vents were for beneath the bed and if yours came that way or if it was something you added. I don't think the hypervent would adversely affect it. If it is to add additional ventilation then I would think the hypervents design would allow the air to come up, and out the sides of the mattress. I would just make sure if these are over the outside storage compartments that they are sealed good so that road rain won't make its way inside up and through these vents.
Equal-I-zer Hitch
"Roadrunner"
Three More 2018 Globetrotter Audio / Visual Modifications ddrg 2018 - Current Globetrotter 17 04-14-2019 08:16 PM
1964 globetrotter in need of modifications to old escape hatch Kljerscheid Roof Vents, Skylights & Fans 1 08-25-2018 10:12 PM
Pricing '69 Globetrotter Modifications my3sonsdad Trailer Values 0 06-28-2011 11:49 AM
Recent Bambi owners wanted! rluhr 1997 - 2004 Bambi 82 09-01-2009 08:55 PM
Recent Model Parts Books in PDF format thenewkid64 Link Archive 1 08-05-2002 01:29 PM
