Old 07-19-2019, 09:19 PM   #1
Kirkland Lake , California
Overflowing freshwater tank
We are hooked up to the camping site water system and our freshwater overflow valve is overflowing. We have no reason for the water system to be flowing into the freshwater tank!
Any ideas? Faulty one way valve?
Kenogami is offline   Reply With Quote
Old 07-19-2019, 09:49 PM   #2
2007 22' International CCD
Faulty or dirty check valve in the water pump will let city water flow backwards through the pump.
Try burping it by shutting off city water. Turn on the pump and open s cold water faucet for 10-30 seconds until the pump runs. Then turn the faucet off. Do this a couple times. Then shut the pump back off, and then try turning city water back on. If water comes out again, that means the pump check valve inside the pump is messed up still.
At that point, Id run off the pump and fresh tank until you can pull out the pump and see if you can repair it or have to replace it. Common problem. Can sometimes be prevented by ALWAYS using a fine particle filter on the city water hose when hooked up or filling the fresh water tank.
Search the forums for lots of threads on this issue. Its not uncommon.
Old 07-20-2019, 05:30 AM   #3
Thanks. We ran on the pump for half an hour and the problem seems to have corrected so must have been a stiff valve or debris in the system.
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
Fuel overflowing into EVAP charcoal canister realpank Classic Motorhomes 15 07-08-2015 04:47 AM
City water overflowing freshwater tank 223002104 Fresh Water Systems 11 03-18-2015 12:17 PM
City Water is Overflowing holding tank??? oldtrucksrul Fresh Water Systems 9 03-29-2014 11:38 AM
Leaky / Overflowing AC... crazy.philip Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-05-2008 07:45 PM
