Originally Posted by Yabadab
Hi everyone,
We are waiting to take delivery on our new Globetrotter in July, but had a few questions. If you are going to use a water softener and an inline water filter, any preference to what order they are in the setup? Also, I see that some people add inverters to their trailer. For what reasons? Also, do people get the surge protector that goes between the end of the rv amp line and the electrical box? Any help would be greatly appreciated! I will post pics when we have her home!
Congradulations on your new AS. Hope you enjoy your new toy.
Response to your water softener, water filter questions. Usually I use the water softener w/o the water filter. On occasion when I don't properly back flush the water softener after I add salt, some of the salt passes through. When that happens I use the water filter "after" the softner to clean it up the salt taste until I can back flush properly.
Not sure with the Globe Trotter models but more recent AS models already have inverters installed. Inverters make AC (house current) current from DC (12 volt battery) current. Typically inverters are used when shore power is not available and you need to run a small AC appliance like a coffee maker or TV for a short period of time. If you have an inverter, you will see inverter AC outlets next to some of your normal AC outlets with a "blue" tag on them saying for inverter use. Also you will see on your "control pannel" a button saying "Push for Inverter"
IMO of all of the after maket goodies you can purchase, a proper surge protector is mandetory to protect your investment. RV parks, including some of the fancy ones, are known to have improperly wired power posts than can cause major electrial failures in your AS. (I learned this one the hard way). Make sure what ever brand you purchase has the following mimum capabilities: 1) Protection against power spikes or surges; 2) Protection against low voltage, high current draw; 3) Protection against reversed wiring
polarity and/or open ground. If it has any other protection features besides these three major ones consider it gravey.
Good luck and safe travels
