Old 08-23-2019, 12:05 PM   #1
2019 27' Globetrotter
Denver , North Carolina
Medicine Cabinet Mirror Height Adjustment
I have seen a few people posting ways of modifying the hardware that holds the medicine cabinet mirror open with springs or gas struts. I don't know if they all originally had the same hardware as the 2018 and newer Globetrotters have, if they do here is a fix for adjusting it's opening height. The Globetrotter uses the Blum Aventos HK-XS "lift mechanism".
The first picture shows the arm detached from the mirror/door. The second picture shows the slide latch to release the arm from the mirror/door. CAUTION the arm is under a lot of tension when you release it be careful! It is easiest to release the arm with the mirror/door about half way closed. The third picture shows the phillips adjusting screw with arrows indicating more or less spring tension, below the adjusting screw is a numerical scale window to enable adjusting both lift arms to the same amount of tension.
After some trial and error adjusting I was able to raise the open resting height of the mirror/door to about 1 inch from the ceiling keeping me from banging my forehead into the bottom edge when it's open.
Name:	Mirror Arm Detached.jpg
Name:	Release Slide.jpg
Name:	Adjust Screw&Tension#.jpg
Dave S
link2dks is offline   Reply With Quote
Old 08-24-2019, 01:39 PM   #2
2018 27' Globetrotter
Mooresville , North Carolina
Dave,
I just made my adjustments today and it works like a charm. I think I ended up at about 6.5 on the adjustment scale. The other benefit for me is that with the opening up higher I get more light into my cabinet from the open skylight outside the door (I don't have the motion sensor lights as you do at this time).
Great idea / info!
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Plastic medicine cabinet latches willbrackman General Interior Topics 6 05-08-2017 09:07 AM
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 04:14 PM
Heavy mirror above medicine cabinet titleists Cabinets, Counter Tops & Furnishings 12 05-24-2013 11:26 AM
Medicine cabinet door won't stay closed jordandvm Cabinets, Counter Tops & Furnishings 10 10-03-2004 09:24 AM
