Old 03-24-2019, 11:01 AM   #1
Winedog
2014 25' FB International
Walla Walla , Washington
Gas struts installed on cabinet door above fridge
This is an easy project. It is slightly frustrating to access the overhead cabinet when the door wonít stay up.
I used a gas strut made by Apexstone - 45N/10lb available on Amazon.
Position of the strut is crucial or the door wonít close. Here are the measurements:
Top of strut: mount the bracket 3 inches from top of door, and 5/8Ē in from the side
Bottom of strut: mount the bracket 1 inch from bottom of door and 1 inch in from the side
winedog is offline   Reply With Quote
Old 03-24-2019, 11:53 AM   #2
D44
D44's Avatar
2017 25' Flying Cloud
Lawn Guyland , New York
Excellent! What hardware did you use to attach to the cabinet side and underside of door?
Walt
WBCCI - 29375
D44 is offline   Reply With Quote
Old 03-25-2019, 07:43 AM   #3
Winedog
All mounting hardware (brackets and screws) was included with struts.
Old 03-25-2019, 08:51 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Good Job...👍
When did the design change?
Another example of... 'no changes only improvements?'
Our '03' Classic...
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-25-2019, 09:17 AM   #5
2019 27' Globetrotter
Pleasanton , California
Thank you for the detailed "fix". Hate holding it up with my bald head...
Couple questions - Are you measuring from the center of the strut? Did you use 1 or 2?
fubar201 is offline   Reply With Quote
Old 03-25-2019, 11:23 AM   #6
4riveteers's Avatar
2016 27' Flying Cloud
SF Greater Bay Area , California
Thank you winedog! I’m going to Amazon right now!����
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 03-25-2019, 11:34 AM   #7
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Got the same result with a piano bench lit support from Amazon for $8.
https://www.amazon.com/Piano-Bench-L...gateway&sr=8-1
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 03-25-2019, 11:59 AM   #8
Depends :) , My heart is in Colorado
This is awesome! I've been thinking about how I could configure magnets to hold this door open, but this is a more straight forward approach. Thanks for the great documentation and specs.
Jump, and the net will appear.
Papatango is offline   Reply With Quote
Old 03-25-2019, 12:19 PM   #9
Napa , California
We did the same thing, and just needed one strut. Only real issue we had is that the instructions might as well been written in Klingon -there was no way to directly translate into English that made any sense at all!
But, a quick review online of installing struts and a wee bit of extra "think" and test time and it went very smoothly. Such a cheap and easy fix...makes you sort of wonder why it wasn't done originally.
Atwebs is offline   Reply With Quote
Old 03-25-2019, 12:58 PM   #10
2007 22' International CCD
Probably because it costs a few bucks and a moment of assembly time that comes out of profit for Airstream, but donít pay attention to my cynical viewpoint...
rmkrum is online now   Reply With Quote
Old 03-26-2019, 11:13 AM   #11
2015 25' FB Flying Cloud
Charlotte , North Carolina
An easier fix and cheaper also is to get a spring type hatch support from West Marine. This also works for the large hinged mirror in the head.
MaiziesGang is offline   Reply With Quote
Old 03-27-2019, 08:00 AM   #12
Winedog
Diagram of strut placement mounting brackets
http://www.airforums.com/forums/atta...1&d=1553695081
Old 03-27-2019, 09:43 AM   #13
2016 27' International
Anacortes , Washington
Can you provide a larger image, please
The provided image of your sketch showing the dimensions doesn't enlarge like your photo of the completed strut. So when I try to enlarge the small image, it is too blurry.
We too have thought about struts others have installed, but knew exact placements of the strut ends would be challenging. So with your success and exact placement dimensions, we are ready to proceed!
Thanks for posting!
Pat Pierce is offline   Reply With Quote
Old 03-27-2019, 10:42 AM   #14
Winedog
Hopefully this is more clear.
http://www.airforums.com/forums/atta...1&d=1553704816
Gas spring struts for mattress lift RLS General Interior Topics 7 12-04-2018 08:44 AM
Need cabinet struts. mapley3 Cabinets, Counter Tops & Furnishings 0 07-26-2013 09:59 PM
TV mounting - cabinet above fridge rodsterinfl Audio, Video & TV 4 03-09-2012 11:50 AM
How do I remove the cabinet above the fridge? RV H-D Lady All Argosy Trailers 13 12-11-2010 04:29 AM
Gas assist struts for lifting bed to access storage. Phil/Edee General Interior Topics 13 09-27-2007 10:12 AM
