Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 2018 - Current Globetrotter
Old 04-08-2018, 10:03 PM   #1
2019 27' Globetrotter
Larkspur , Colorado
Galley sink water filter?
So we are in the process of buying our first Airstream (delivery in September). We originally were on the path to a FlyingCloud but liked the finishes in the GT much better.
One thing I noticed in the options and in videos has been there is no mention of a water filter on the GT (as compared the the FC). Can anyone confirm it’s absence/presence?
Thanks!
Derek
Dmmdtm is offline   Reply With Quote
Old 04-09-2018, 03:17 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
Not able to answer your question but I will say we removed the filter in our flying cloud and now use a filter at the water hookup, providing for filtered water prior to entering our unit.
majorairhead is offline   Reply With Quote
Old 04-13-2018, 03:31 AM   #3
chaseav's Avatar
2015 25' FB International
Get the Camco filter that goes on the outside at the water line. It filters everything in the entire AS that way and requires no modifications.
chaseav is offline   Reply With Quote
Old 04-13-2018, 03:57 PM   #4
Larkspur , Colorado
Whole Trailer Filter
Thank you both...That's exactly what we'll do.
Old 04-21-2018, 01:19 PM   #5
Lve42dy's Avatar
2018 27' Globetrotter
Jeffersonville , Indiana
Thank you for the information as well. I was told that the ASs no longer are fitted with water filters. Glad to see the reference to an external one.
Lve42dy is offline   Reply With Quote
Old 04-22-2018, 09:54 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Agreed. We had a filtered water dispenser on our Limited. We don't miss it at all. It really was kind of a pain to remove and install when winterizing. We do use the Camco filter at the pedestal connection. Does a good job of preventing grit from building up in the system.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-02-2018, 04:40 PM   #7
chaseav's Avatar
Our 25FB had a water filter for the kitchen sink. A noble idea but it leaked! It came with a bypass tube which got installed immediately after. That leaked too once in a while until I really cranked down the fittings. That experience has lead me to religiously turn off the water at the hookup if we leave for more than an hour.
Old 05-03-2018, 07:02 AM   #8
2016 28' International
Sioux Falls , SD
The filter under the sink was to get rid of the holding tank taste correct?
How is that being dealt with now?
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 05-04-2018, 08:18 PM   #9
chaseav's Avatar
Well, I never thought of that! We don't ever (and I mean EVER) drink what comes out of the holding tank. I just can't trust that some nasty algae didn't find a way to grow down there over the winter. I usually fill to 25% with some Clorox mixed in and use it for toilet water while on the road. But you're totally right, if you want to filter and drink what's in the holding tank, the external filter won't do it.
Old 05-04-2018, 08:21 PM   #10
chaseav's Avatar
Wait! If you use the external filter, when you go to fill the holding tank, you just do it with filtered water. That leaves the matter of trusting what's already down in there though.
Old 05-06-2018, 06:25 AM   #11
Sioux Falls , SD
I think they are saying they use bottled water to drink. Filter INTO the tank and use the tank for showers, toilet etc.
I would like to know who/ how many still use the under sink filter and if they have any tips.
Old 05-06-2018, 08:21 AM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We have both filters. The outside doesn’t filter as much and you can get really good ones...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-07-2018, 05:35 AM   #13
Sioux Falls , SD
What type of under sink do you use?
Old 05-07-2018, 07:39 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My solution.
We had an 'Everpure' filter.. installed in 1999 when Mjolnir was built. As it would have it, there are no filters 'available' or manufactured for our filter head assembly... or this post may never have happened.
Here is a link... it is a 3M filter head at Lowes:
https://www.lowes.com/pd/3M-Single-S...tem/1000068813
The filter removes most of the stuff we are concerned about..
- Reduces 99% lead reduction and microbial cysts for healthy living filtration
- Lead and microbial cysts may or may not be in your water
- Provides enhanced reduction of chlorine taste and odor, sand, sediment, rust, and soil
- Installs in less than 30 minutes
Maintains high water flow at 1.5 gallons per minute and requires no dedicated fa- ucet head
- 1,500 gallons capacity with a 6-month filter life
This is the filter cartridge... # 790058 Model # 3US-MAX-F01H
Obviously there will be plumbing changes.. Time will tell how it holds up to RV life...
Since there is no 'lock' to secure the cartridge, I used a long velcro strap, looped from top to bottom and back up. It fits into some grooves on the bottom of the filter element. Rotation should be minimal.. again, the trip to International will show any issues.
I also carry a few PEX components which I used for the install. It helps to be near a plumbing store for the install... because while most fittings are there for a new install, your situation may be different where you want to install, etc.
There are some 'kit's you can buy for 'sink water dispenser'.. as well as small Osmosis systems.. if you have need for the best water filtration...
Be well
Channing
WBCCI# 30676
Galley faucet filter in 2014 Sport 22FB? MN Jeff 2005 and newer - Bambi all models 2 09-25-2015 07:05 PM
Galley Faucet Filter: 2015 FC 28 DeltaRon Winterizing, Storage, Carports & Covers 1 08-19-2015 05:10 PM
Replacing Sink and Faucet in Galley 1Michigander Cabinets, Counter Tops & Furnishings 15 04-21-2008 11:35 PM
Galley Sink Paint Pealing Off Cracker Sinks, Showers & Toilets 1 04-21-2008 05:47 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
