Installed the Wilson 4G-X OTR running the cable through the emergency exit window. Mounted unit behind TV so I'm set for 120v but wondered if anyone has a wiring diagram that might show where I could pick up a 12v feed. Would prefer not to run a new one under the RV and make more holes.
I don't have a 25FB, but looking at the floorplan, if you can get a wire under or behind the shower, you can pull from the 12v light in the wardrobe. If, as I assume, the power center is under the refrigerator, you could pull a new wire from the fuse board under the wardrobe and the shower.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Is there a chase under the floor or do you have to go outside the belly pan?
The wardrobe has a switch but that's likely just the hot leg switch so it's more probable that I'd need to drop the fan or ceiling fixture in the shower. Just don't know how they wire these things.
Airstream is very helpful about things like this. I recently asked for - and received within 20 minutes - a set of 120VAC and 12VDC electrical schematics for my '07 25FB. Email customer_support@airstream.com, give them your year, model, and VIN, and they'll most likely tell you what you need to know.
That works perfectly. I have the electrical plans and they added plumbing.
Quick and fast.
Just make sure to give them your VIN.
Should find a place to post them here.
