Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 03-24-2017, 02:17 PM   #1
San Clemenete , California
Where is the CAT5 Data Cable for the Solar Controller Remote
Hi--
2016 FC 23 FB
We have installed the Zamp panels on the roof wired the panels to the controller through a combiner box. Attached the controller to the batteries.
Attached the comptroller to the inside wall of the front storage cubby cabinet next to the battery. Controller reading 10 Amps plus in sunshine, All works great. That is 2-60w and 1- 100w panel. About 12 Amps total
Used the yellow and green pre wired solar that was tucked into the front
Fan-tastic molding and found the other end under the bed near the electronic bus.
Belden data wire was there as well . Found the end bundled under the bed
The CAT 5 right with the yellow and green.. Plugged it in to the controller.
Where is the other end.
Looked in the bathroom wall under the "SeaLevel" tank monitors
Not bundled. Airstream tech say it should be there, the book says it should be there. Looked with a cavity camera and the electrician/tech.
Took out all the switches and vent at shoe level..
Sorry..Nothing.. Just the wire bundles to the switches and "SeaLevel" monitors
Any ideas where it should be routed or where it may have disappeared.
I have used a lot of CAT5 data cable. It is the same stuff that goes from your computer to modem/router. It is an ether-net cable.
Any ideas or input would be appreciated.
Thx
Steve and Carolyn
CarolynSteve is offline   Reply With Quote
Old 03-24-2017, 10:48 PM   #2
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I have a 2017 23D. That cable was behind the inverter on/off switch on the wall with the sink. My see level monitor was above that. I can dig up some pictures if that would help
Troutboy
Troutboy is offline   Reply With Quote
Old 09-07-2022, 07:03 PM   #3
mustang , Oklahoma
are you still searching for the cat 5 cable location or did you find it?
amixon is offline   Reply With Quote
Old 09-08-2022, 06:42 PM   #4
Bartlett , Tennessee
Since that post is 5 and 1/2 years old, I would guess he found it.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 09-09-2022, 10:40 AM   #5
mustang , Oklahoma
Thanks Bobbo, I figured they had, just wanted them to tell me where they ended up finding it. I have the same trailer and have traced it to a point where it disappears into the outer wall behind the black tank. Doesn't make sense why they routed into an outer wall in the bathroom when the interior wall with the controls is open from the bottom and has ample room to mount the monitor.
Data Gathering for Solar Install chris_kelly Generators & Solar Power 6 03-11-2016 04:22 AM
Solar Ele on the roof or remote? Oxen Generators & Solar Power 16 09-16-2015 05:02 PM
CAT5 for Blue Sky IPNPro Remote? mikebee Electrical - Systems, Generators, Batteries & Solar 1 12-01-2014 07:23 AM
Weatherproof CAT5 connector box perryg114 Computers, Internet & Satellite 10 06-07-2014 04:47 AM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
