11-26-2016, 09:28 AM
2017 25' Flying Cloud
Rancho Mirage
What type Generator
Hello we have a new 2017 25 Flying Cloud Rear twin with one ac Looking suggestions on a generator Honda, Yamaha? Size?
11-26-2016, 09:38 AM
2019 27' Globetrotter
Salem
, Oregon
IF you want a great generator at a good price look at the Champion at Costco
They have the 2800 w 3100w running for $699.00 or go with the dual fuel
propane/gasoline of $849.00
Either will be great for all your needs including running your air conditioner.
If you go with a smaller generator 1800/2200 range from any number of vendors you will need two to run your air conditioner.
There are many threads on generators here if you need more info.
Dave
11-26-2016, 09:39 AM
2018 27' International
Southeastern MI
, Michigan
There are many options besides the two you mentioned. About 3000W should do it. Get an inverter type, they are quieter. I ran them all before buying mine, got a Briggs and Stratton 3000 inverter.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
11-26-2016, 10:53 AM
2008 25' Classic
Full Time
We don't plan to run AC in dry campgrounds so I went with a propane converted Honda 2000. I love not having to deal with extra gas containers and having possible issues with a fowled fuel system. I carry a 20lb tank but could also connect it to one of my 30lb tanks. Champion offers a 3000w dual fuel generator. We figure if its too hot we can move or find an RV park with hookups. The 3000w generators are just too heavy for my old back.
Kelvin
11-26-2016, 11:42 AM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Given we also don't plan to use AC while boondocking, we did the same as KJRitchie with one propane-fueled Honda EU2000i Companion from GenConnex Direct. They also offer a propane fueled version of the Honda EU3000i, which should be able to run your AC. It's supposed to be even quieter than the EU2000i, though it is considerably heavier.
GenConnex Direct will *not* be your least expensive option, but it is a solid choice if you want a propane-fueled generator.
If you want the EU3000I for off-grid AC, here's what you might check: http://www.genconnexdirect.net/honda...d_packages.htm
If you think you can go without AC while boondocking, you might check these options: http://www.genconnexdirect.net/honda...g_packages.htm
"When people show you who they are, believe them the first time." - Maya Angelou
11-26-2016, 02:30 PM
Rancho Mirage
Thanks All!
11-26-2016, 04:39 PM
2016 25' Flying Cloud
Venice
I have a Yamaha 2000 that I carry in my truck bed for at need use. It will fire up everything except the AC. I wasted $800 a few years back on a 3000w cheaper model that I eventually gave away because of constant issues. Yamaha or Honda are more costly but worth the money. BTW to run the AC unit buy two & parallel them for less than $2000 total & you have the option of leaving one home if not needed on any trip.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
11-26-2016, 05:28 PM
Rancho Mirage
11-26-2016, 06:43 PM
2016 30' Classic
Houston
We too went with one propane-fueled Honda EU2000i from GenConnex Direct. Didn't want to hassle with gasoline storage. Only wanted a Honda gene my good experience with the brand. Originally, was going to get a companion Honda2000i so that I could run an AC - have since installed a solar / lithium system so the single Honda 2000i is sufficient to supplement my needs. Good luck. Dennis
11-26-2016, 07:11 PM
2014 30' Flying Cloud
Tampa
This is the one I'm looking at for my FC30
http://www.campingworld.com/shopping...ic-start/93723
It will run on propane, run one of my ACs, and is quiet. All for $1100.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
11-26-2016, 07:22 PM
Sag Harbor
, New York
Welcome to the forum!
It might help if you define your parameters a bit more, so as to narrow down the possibilities.
-- do you want to use the A/C reliably?
-- what extra weight and volume can your tow vehicle [TV] carry?
-- can you lift a single 3000 to 3500 watt gen in and out of the TV?
-- are you comfortable with using 2 (lighter) mating gens, like the Honda 2000 pair?
-- will you be able to transport gasoline containers in/on the TV?
-- would you consider a propane-fueled modification/alternative gen?
-- what is your budget?
-- etc.
As someone else mentioned, there are lots of earlier threads on the sub-forum which is dedicated to generator issues:
http://www.airforums.com/forums/f448/
You might peruse the list of topics, as there are probably a few threads which would be helpful to read, to bring you up to speed. There are so many variables that you are going to get a wide range of opinions here. Narrowing your focus will help IMO.
Good luck!
Peter
11-27-2016, 08:21 AM
Rancho Mirage
Peter I know this has to had to come up before but to be honest The forum really isn't user friendly The first thing I did was search. But nothing came up . I searched in this thread and at the main screen. I must of been searching in the wrong area . My tow cap is 11700 on a 7300 25 foot FC . I'm prob not going to be running ac when dry and budget is always a concern . I am interested in solar too , but I'll check that out later . So From the suggestions I've received I like he tandem option . I appreciate all the suggestions here and will try and be more specific in the future. Thanks much Larry
11-27-2016, 09:12 AM
Sag Harbor
, New York
Thanks Fred, yes the search function is not the best, but there are lots of work-arounds that can help.
For instance check Janet's Post #5 here:
http://www.airforums.com/forums/f138...lp-156991.html
and Post #9 here by yours truly:
http://www.airforums.com/forums/f138...es-145169.html
Once you get used to the organizational structure of the topic outline here, things get easier. For instance, click on Forums tab at the top left, and check it out:
then dive into each topic area to see what is contained there. You have probably done this already, so FWIW and FYI . . .
Cheers,
Peter
PS -- Yes the tandem Honda 2000 units (and other brands) are a very popular setup. We were about to get a second Honda 2000, when I discovered the Yamaha 1000 tri-fuel option from US Carb, which we decided to give a try. During our hurricane season, the extra 1k generator, running off a BBQ 20-pound cylinder, was a big draw as it it is very portable, and can handle a variety of small loads here and there around the house. Plus it fits in our tow vehicle van well, and does not have any gasoline to worry about inside the van.
11-27-2016, 10:14 AM
1973 Argosy 24
hartselle
, Alabama
Yamaha 2400 gas burner will pull your camper, ac included. It's a single unit that is lighter than two hondas, and has the same fuel sipping abilities and quietness as the hondas. A single gallon of fuel will run almost 12 hours at 1/2 load and about 6 hours pulling the ac.
11-27-2016, 10:24 AM
2005 25' International CCD
Westlake Village
2800W Champion Duel Fuel from Costco. We chose that having similar rig to you with one AC. Competively Quiet, great build quality, Electric start and almost 0 fumes as we now prefer to always use propane for above reasons. Analyzed Honda and Yamaha versions for months and VERY pleased with this version of Champion. Many others on this forum agree. Ol' standards great as well.
Happy camping.
11-27-2016, 10:28 AM
1973 Argosy 24
hartselle
, Alabama
And I carry my genny on a cargo carrier mounted on a front hitch of my tow vehicle. As a general rule I chain the generator to the hitch carrier before a trip, and that is where it stays for the duration. Don't have a picture of the generator on the carrier but this picture should give you the idea. If you tow with a van or suv I believe the front hitch to be a necessity.
11-27-2016, 10:32 AM
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury
I am curious why no one is using the 2000 gen set from Northern Tool. It is just a drop noisier than the Honda but everything else the same. Cost is $599.
11-27-2016, 10:55 AM
1973 Argosy 24
hartselle
, Alabama
I was running a 2000 Honeywell before buying a Honda 2000 from a friend. I was impressed with the Honeywell until I bought the honda, the Honda starts easier and was way more quiet. Staring down having to buy a second honda to run the ac led me to the yamaha 2400. For me it was a common sense choice, one generator burning fuel verses two. While the specs show the Honeywell is only a decibel or two louder than the honda or yamaha, the actual difference in sound level is very noticable. I never had anyone complain over the Honeywell noise level but sure sleep better with the yamaha running. Inside the trailer you can't hear the yamaha/honda with it right off the backside of the trailer, the Honeywell produced a noticable "hum" inside the trailer.
11-27-2016, 12:26 PM
2015 25' Flying Cloud
GILBERT
One of the most important thing is the WEIGHT, Honda is under 50lbs, the lightest and the quietest on the market.
Test yourself, How much dead weight can you pick up??
GenConnex Direct is the best deal and with propane you do not need to carry gas and be refilling it all the time, has best warrantee.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
06-25-2019, 05:21 PM
Olive Branch
, Mississippi
Originally Posted by FCStreamer
The link is no longer any good. What is the make and model of the generator, please.
