Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 04-28-2017, 05:10 AM   #1
2017 23' Flying Cloud
Bartlett , Tennessee
What are these valves? (FC 23FB)
I have just bought a Flying Cloud 23FB. The manual shows this plastic drain valve to empty the fresh water tank. It does not, however, address the 2 metal valves below the plastic one.
What are the 2 metal valves for?
Bobbo is offline   Reply With Quote
Old 04-28-2017, 05:25 AM   #2
Sag Harbor , New York
Guessing they are hot and cold water low point drains. Your owner's manual should tell you someplace. The plumbing info is all over the place. Maybe under Winterization section?
Fill the water and turn on the water heater, then open each valve and see what comes out. Full scale model . . .
BTW you might want to add your AS year and model to your signature.
Have fun!
Cheers,
Peter
Old 04-28-2017, 05:31 AM   #3
That is my guess too, but I would like to KNOW.
Old 04-28-2017, 05:34 AM   #4
Fill and heat water. Open drains. Knowledge via action. Earlier comment edited re manual too.
Happy Trails.
Old 04-28-2017, 05:35 AM   #5
That will work when I bring the trailer home in 2 weeks. I still haven't taken possession yet.
In the meantime, does anyone know the answer to the question?
Old 04-28-2017, 06:27 AM   #6
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
They are definitely low point drains, same configuration on my 25FB. On mine, they are not the only drains, however.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-28-2017, 06:32 AM   #7
The 23FB also has low point drains at the other end of the trailer that are configured as usual low point drains, tubes sticking down, with valves above inside the trailer. Those are also documented in the manual. The metal ones at the fresh water tank are not documented in the manual that I have been able to find.
Old 04-28-2017, 06:55 AM   #8
I think AS has at random times decided to add these brass valves as additional low point drains, probably after getting warranty complaints about freeze-ups in the system which they did not expect.
The factory assembly process is pretty chaotic IMO, with inconsistent quality control, and if a horizontal plumbing run is not level (or pitched correctly) as-built, it can result in a low point, say at an elbow, where there is no low point drain designed in to the system.
CruizinDux on the 20-footer thread documented just such a situation, and the dealer re-worked his piping at the water heater, to get things level/pitched so his low point drains worked.
These added brass valves have been discussed in other threads, but I don't recall just where right now.
As I said earlier, the owner's manual is really inconsistent and incomplete.
Oh well, in a couple of weeks you will know. Sometimes we have to treat our trailers as full-scale models. Seriously!
Cheers,
Peter
Old 04-28-2017, 01:28 PM   #9
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Same as on my 23D, low point drain valves.
banderabob is offline   Reply With Quote
Old 04-28-2017, 03:53 PM   #10
Good. That is what I hoped they were.
Old 04-28-2017, 09:39 PM   #11
Granbury , Texas
Yep...that picture is of typical airstream low point drains
It's been several years but our 23FB also had a removable panel below the slide-out pantry with some pex pipe with cut-off valves that lead outside the trailer floor also called low point drains.
Go easy on these valves turning them on and off...especially the plastic water tank drain.
cabinetmaker is offline   Reply With Quote
Old 04-29-2017, 05:20 PM   #12
2014 23' Flying Cloud
Rhinebeck , New York
Thumbs up Low Point Drain Valves
Ditto the response about the low point valves. I winterize opening the drain valves in the rear of the 23D (under the bed) and then open the two valves under the unit (literally between the wheels). Haven't had any issues thus far with the 2014 International Serenity23D. We also have a 2017 Bambi 16' Sport which I've yet to de-winterize. A simpler system however
Adam Geuss is offline   Reply With Quote
Old 04-30-2017, 11:36 AM   #13
FYI a new thread on the 23D model with possible overlapping systems and mechanical layouts:
http://www.airforums.com/forums/f142...ad-166085.html
Happy Trails!
Peter
Old 04-30-2017, 04:14 PM   #14
Thanks, I have just subscribed to it.
Old 05-01-2017, 09:01 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Have fun!
Cheers,
Peter
That is correct.
The valves are low point drains.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-02-2017, 08:55 AM   #16
2017 27' Flying Cloud
Lake Forest , Illinois
In our 27ft front bed FC - there is also a black valve located on the floor under the water heater by-pass valve that seems to do nothing other than connect the city water inlet back to the outside world through a drain that exits close to the water heater location. Took me ages to figure out and thought I had a major leak when I dewinterized! Not mentioned in the user manual. Difficult to see as well.
kjbishop2 is offline   Reply With Quote
Old 05-02-2017, 05:23 PM   #17
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
As mentioned they are low point drains. There are two more under the slide-out pantry that are accessed by removing the panel under the pantry. It pops off easily.
pcskier is offline   Reply With Quote
Old 02-21-2018, 10:50 AM   #18
2020 23' Globetrotter
Savoy , Texas
The 2 black drain valves under the pantry in our 2018 23fb are difficult to turn. I have even tried to get pliers on them but with no movement. Any suggestions? Are they clockwise or counter clockwise?
SpinWhite is offline   Reply With Quote
Old 10-29-2018, 11:07 AM   #19
billrector's Avatar
Fort Worth , Texas
Did you ever figure out what this valve is for? I am winterizing and found the same valve today. Did a search...and voila....found this post!
billrector is offline   Reply With Quote
Old 10-31-2018, 06:45 AM   #20
billrector's Avatar
Fort Worth , Texas
Figured it out....seems to drain water when opened to a pipe just under the water heater outside. Got some water out of it when I had compressed air on the water inlet and opened the valve.
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
23FB Bypass Valves schkube Fresh Water Systems 4 02-09-2014 10:35 AM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
What do these valves do? mello mike Fresh Water Systems 5 08-16-2009 08:55 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
