Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 2016 - Current Flying Cloud
Old 10-23-2021, 01:22 PM   #21
2018 23' Flying Cloud
Dallas , Texas
Originally Posted by SpinWhite View Post
The 2 black drain valves under the pantry in our 2018 23fb are difficult to turn. I have even tried to get pliers on them but with no movement. Any suggestions? Are they clockwise or counter clockwise?
I’m having issues as well getting them to turn, I see a screw in the top of the valve, not sure if that’s a factor. What did you find worked out for you?
kdgattis is offline   Reply With Quote
Old 10-24-2021, 05:28 PM   #22
2020 23' Globetrotter
Savoy , Texas
I got a small pair of pliers and got it to turn. Turned the valve several times. I don’t turn them hard against the end of their travel. That seems to help.
SpinWhite is offline   Reply With Quote
Old 10-25-2021, 06:25 AM   #23
Dallas , Texas
Thanks that’s what I did.
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
23FB Bypass Valves schkube Fresh Water Systems 4 02-09-2014 10:35 AM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
What do these valves do? mello mike Fresh Water Systems 5 08-16-2009 08:55 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
