Old 08-25-2015, 05:03 PM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Boomer, there are several long threads here about the fridge noise. Many have replaced the OEM fan with quitter and higher output computer fans. Also the addition of a fan on/off switch is a popular addition. I did both and it improved the perceived interior Db level.
MICHAEL
Old 08-25-2015, 10:26 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I replaced the noisy fridge fan with a quiet computer cooling fan. Can't hear it run inside, barely outside.
Doug and Cheryl
Old 08-26-2015, 09:05 AM   #17
2016 28' Flying Cloud
Frostproof , Florida
My dealer is aware of the problems. They would have fixed it at dealer, and they offered to send a service man to me and fix it. Also airstream called me to help. We decided easy way was they sent me a kit to pull and reseal vent.
As far as the water heater pressure, if i just open a facet for a few seconds as water is first heated i have no leaks.
jczednick is offline   Reply With Quote
Old 08-26-2015, 04:12 PM   #18
2015 25' Flying Cloud
Woodinville , Washington
No, we have not experienced that with ours, but
We have a 25' Flying Cloud twin 2015 and have had a water leak from the shower. They replaced the wall and now we have a large gap behind the wall.and interior skin.
alavekios is offline   Reply With Quote
Old 08-27-2015, 08:12 AM   #19
boomer111's Avatar
2016 23' Flying Cloud
leavenworth , Washington
thank you for the fan idea....can I get one of these fans at any computer outlet online? how about the wiring? same?
boomer111 is offline   Reply With Quote
Old 08-27-2015, 08:23 AM   #20
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I used a Silenex fan- 90cf and 18dB. I've used the same fan for several years in two different Airstreams. This week it failed. The refrigerator is a much harsher environment than a desk top computer. I replaced it with a cheap one from Best Buy, the only one I could find. It's very quiet, but doesn't move a lot of air. When we get home, I'll replace it.
2012 Dodge Durango Hemi/AWD
Old 08-27-2015, 08:43 AM   #21
1978 31' Excella 500
Barrie , Ontario
Reading about all the leaks and other problems with the new AS, I'm glad I'm still towing my 1978 ! Its not as shiny as I'd like and the inside is pretty plain but the only leak its ever had was around one roof vent!
Bev1940 is offline   Reply With Quote
Old 08-30-2015, 06:13 PM   #22
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Yes, new coach, leaked from multiple points from day one, day ... after dealership return, ... after dealership return, and now scheduled for a trip to JC for warranty repairs.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 08-30-2015, 09:17 PM   #23
2016 30' International
Scottsdale , Arizona
Those considering a new Airstream, don't freak. Our 2016 30' Serenity has been through some heavy downpours, including hail and we haven't found any evidence of a leak. Doesn't mean they aren't happening, but at least there are no evident problems right off the bat. Everything works! Only possible issue is that the fridge didn't seem to be cooling well enough in 100* weather. (Would only go down to 40*). We're in much cooler temps now and it's OK, but still monitoring carefully. And if 100* temps are expected to be the norm in an area where we're "camping", we'll just get on the road to someplace cooler anyway.
DHart is offline   Reply With Quote
Old 08-30-2015, 09:45 PM   #24
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
Doug, question on finding leaks, When you find them how do you handle it? The reason I ask is bout the flooring. Do you replace the flooring each time or what are some strategies?
WBCCI 8653
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 12-23-2015, 04:39 PM   #25
2016 25' Flying Cloud
East Falmouth , Massachusetts
2016 flying cloud FB just found leak on rear curved window small but water coming in right where roof panels meet (3)all seams look good so far what did you do.Never used the trailer drove it 250 miles home and a leak nice.same day get a recall for gas regulator travel 500 miles why don't they just send me one
paul
miskeeta is offline   Reply With Quote
Old 01-03-2016, 03:56 PM   #26
2016 27' Flying Cloud
North augusta , South Carolina
We had leaky connections under the bathroom sink, and the fresh water intake leaked into to wardrobe.
Medjrd is offline   Reply With Quote
Old 01-03-2016, 04:07 PM   #27
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I've been lucky as well. No leaks on my 2014 FC 25. Well correction not from the outside anyway. The filters under the sink had a good leak and made a mess. You would think stuff like that would be checked. Go figure.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 01-04-2016, 05:18 PM   #28
2016 30' Flying Cloud
Port Saint Lucie , Florida
Do you need to check the pressure once in a while ?
Originally Posted by dkottum View Post
The bubble inside the water heater protects the hot and cold water system from leaks due to thermal expansion when the water heater heats the water.
It doesn't work very well because it does not last long. Especially the newer models with both electric and propane water heaters that get very hot. The air bubble will eventually be absorbed by the water, or the bubble will be lost when the water pressure/temperature relief valve on the heater releases water, steam and air.
Then the bubble is gone and the thermal water expansion will find the fitting with the least resistance, or constantly leak out the wp/t relief valve.
We installed a water pressure accumulator which has its own air bubble separated from the water by a rubber membrane, and an air valve so you can put as much air in it as you need. It comes preloaded with 30 psi if you get the one we got at Camping World. I installed it under the bath sink by taking loose the cold water line at the faucet, hooking that line to the accumulator, and running a new supply line from the other side of the accumulator to the faucet.
Here's a picture.
I'm interested in fitting one. Do you have a before pic? I assume the cold feed into the cold water system from any position is ok for fitting. What about the water pump feed?
Also in reply to op, we took delivery of our 2016 FB 30ft 3 weeks ago and although not camped in yet, the water system was pressured and so far no leaks. No leaks from 'holes' in the body either. Again in some Florida downpours.
Our 2015 27 FC (long story but no real issues) did spring a leak on the water line exit from the heater. I look for these things so it was quickly cured.
Regards
Brian and Esta
2016 Flying Cloud 30 Rear Bedroom with 2 a/c + window awnings.
2014 GMC Sierra 3500HD SLT Crew Cab Duramax 2WD
ttsr4us is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 10:40 AM
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 12:36 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 12:23 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-28-2007 12:03 AM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 06:49 PM
