08-16-2016, 04:42 AM
#21
Sag Harbor
, New York
Originally Posted by trigal
not yet Peter but thanks for checking. need to go to service center somewhere to have it checked out.
Were you able to solve this problem?
Peter
08-16-2016, 10:49 PM
#22
1977 Argosy 28
Euless
Originally Posted by rvb
I have a newer refrigerator and it quit working 2 weeks ago on propane. I blew out the burner tube with an aerosol computer spray and also around the the sides to get air near the burner and it fired right up. My units air intake is in the floor below so my burner was full of dirt. Turn off the unit before you spray or you will get fire out all the sides. You should be able to hear the burner from the access door when it comes on.
I was on a 7 week trip when I blew it out and it ran for about 2 weeks then quit. When I got home I removed the cabinet side panel and pulled the flue baffle and cleaned it off. The manual for my refrigerator shows the burner open under the flue tube but mine is up in it and attached so I could not remove it or clean it. My son is a trumpet player so I absconded with one of his trumpet flex cleaning brushes which is flexible coiled metal rod with a small bristle brush on each end. There are several sizes of brushes and I took the smallest which is just the right size. I was able to fit it into the burner tube without removing it and brush all the way up to the burner. I then blew it out again and it now works. That brush is now in my took kit!
08-17-2016, 04:00 AM
#23
Sag Harbor
, New York
rvb you may also have removed a nascent spider nest in that process IMO, resulting in better ignition and burn of the propane.
08-17-2016, 08:23 AM
#24
2016 25' Flying Cloud
Celebration
Peter (Otra15)
thanks for checking, I have appointment on the 26th to get equalizer hitch adjusted and will have water heater checked. it works on electric but not on propane. Red light does not even blink.
thanks, Jo
08-17-2016, 10:17 AM
#25
Sag Harbor
, New York
Thanks. You could check for spider nests in the meantime, which moved up a notch in likelihood (IMO) given that it works on electric.
08-17-2016, 10:49 AM
#26
Princeton
, New Jersey
You will have to remove the burner tube to check. Simple blow out will not dislodge them.
2004 Excursion 4x4
08-17-2016, 10:56 AM
#27
Sag Harbor
, New York
Correct. rvb mentioned brushes also.
08-26-2016, 06:41 PM
#28
Celebration
Well as it turned out there is a pigtail connection that had a wire come out. Thus no propane. All taken care of under warranty. Thanks for all the suggestions.
08-28-2016, 09:16 AM
#29
Sag Harbor
, New York
Thanks for the update!
Peter
