Old 07-07-2016, 08:47 AM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is odd that spiders would get in both burner tubes or pilot tubes at the same time but it is something that could be the problem.
If you remove the tubes you have to look very well because those little buggers are small. Another invader are stink bugs.
2004 Excursion 4x4
Old 07-09-2016, 07:29 AM   #16
Long Island , New York
I agree but it is one of the possibilities moving up the list IMO.
trigal, were you able to check for spider or stink bug nests in the burner tubes of the fridge and water heater?
Have a good weekend!
Peter
Originally Posted by trigal View Post
Fridge has power. Will check circuit breakers on Friday. Thanks!
Old 07-09-2016, 08:05 PM   #17
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
I have a newer refrigerator and it quit working 2 weeks ago on propane. I blew out the burner tube with an aerosol computer spray and also around the the sides to get air near the burner and it fired right up. My units air intake is in the floor below so my burner was full of dirt. Turn off the unit before you spray or you will get fire out all the sides. You should be able to hear the burner from the access door when it comes on.
rvb is offline   Reply With Quote
Old 07-10-2016, 08:19 AM   #18
2016 25' Flying Cloud
Celebration , Florida
So got fridge running on propane, no problem, must have been operator error!
However water heater on PP no workie. No red light no clicking, no nothing. So will check out someone to clean out as I have no clue but will sure learn. Thanks for all the trouble shooting help y'all!
trigal is offline   Reply With Quote
Old 07-19-2016, 04:21 PM   #19
Wondering if you got this sorted out?
Peter
Old 07-20-2016, 03:18 PM   #20
not yet Peter but thanks for checking. need to go to service center somewhere to have it checked out.
Old 08-16-2016, 05:42 AM   #21
Were you able to solve this problem?
Peter
Old 08-16-2016, 11:49 PM   #22
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
I was on a 7 week trip when I blew it out and it ran for about 2 weeks then quit. When I got home I removed the cabinet side panel and pulled the flue baffle and cleaned it off. The manual for my refrigerator shows the burner open under the flue tube but mine is up in it and attached so I could not remove it or clean it. My son is a trumpet player so I absconded with one of his trumpet flex cleaning brushes which is flexible coiled metal rod with a small bristle brush on each end. There are several sizes of brushes and I took the smallest which is just the right size. I was able to fit it into the burner tube without removing it and brush all the way up to the burner. I then blew it out again and it now works. That brush is now in my took kit!
Old 08-17-2016, 05:00 AM   #23
rvb you may also have removed a nascent spider nest in that process IMO, resulting in better ignition and burn of the propane.
Old 08-17-2016, 09:23 AM   #24
Peter (Otra15)
thanks for checking, I have appointment on the 26th to get equalizer hitch adjusted and will have water heater checked. it works on electric but not on propane. Red light does not even blink.
thanks, Jo
Old 08-17-2016, 11:17 AM   #25
Thanks. You could check for spider nests in the meantime, which moved up a notch in likelihood (IMO) given that it works on electric.
Old 08-17-2016, 11:49 AM   #26
HowieE's Avatar
Images: 12
You will have to remove the burner tube to check. Simple blow out will not dislodge them.
2004 Excursion 4x4
Old 08-17-2016, 11:56 AM   #27
Correct. rvb mentioned brushes also.
Old 08-26-2016, 07:41 PM   #28
Well as it turned out there is a pigtail connection that had a wire come out. Thus no propane. All taken care of under warranty. Thanks for all the suggestions.
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 02:21 PM
New Water Heater Not Working Properly BobbyWhitit Water Heaters, Filters & Pumps 8 04-18-2010 02:10 PM
Water heater bypass not working Rob30044 Winterizing, Storage, Carports & Covers 7 12-05-2005 07:33 PM
