Old 06-05-2018, 12:08 PM   #1
2018 25' Flying Cloud
Smyrna , Georgia
Water Heater
The water heater in my 2018 Flying Cloud has stopped igniting after 6 successful uses. Both propane tanks are full and all burners on the stove work. The water heater does work when used on electric.
Anyone have this issue and repaired it?
DKGA is offline   Reply With Quote
Old 06-06-2018, 07:27 AM   #2
2018 27' International
Dallas , Texas
Mine did the same thing when my rig was new. The igniter wire was up against the metal refrigerator chassis. After about 500 miles of rubbing, the insulation wore through and the igniter was shorting out against the metal chassis. pulling it away from the chassis and wrapping it in electical tape solved the problem until I could get it to the dealer for a warranty fix. Hopefully yours is the same easy fix.
Tom
2018 International 27FB
Previously: 1960 26' Overlander International Land Yacht
RivetCrazy is offline   Reply With Quote
Old 06-06-2018, 09:58 AM   #3
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi DKGA,
We are sorry for the issue that you are having with your water heater in your 2018 Flying Cloud. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
We look forward to helping you get this resolved. Thanks!
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 06-06-2018, 03:12 PM   #4
Smyrna , Georgia
Thanks, just dropped it off at the dealer.
Old 06-06-2018, 03:31 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Airstream is aware of a bad lot of boards in the new water heaters. Make sure your dealer knows about this and provides a replacement board from a different lot. See:
http://www.airforums.com/forums/f295...ml#post2096974
You posted at the tail end of this thread so you may know but just in case.....
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 09:06 PM
