Old 08-19-2016, 12:51 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Twin bed issues in 26u
I mentioned this in a previous post, but the mattresses on our twins are wider than the wooden support-3" on one side and 3 1/2" on the other side. I called AS and was told that they are designed that way! I went to home depot and bought 2 pieces of poplar 1/2' x 6" x 4'. They had 6' but they were almost twice as much. I rounded off the front corner toward the aisle to minimize bumped shins. I mounted them so that 2 3/4" would hang off the edge of the bed frame. I used #6 x 1" countersunk screws. While at the Depot, I also bought two carpet anti-slip pads that were 2'x 8' and trimmed to fit.
I was almost done when I noticed that the streetside plywood was not supported about 18" from the head of the bed. Apparently, it is supposed to sit on top of the partition between the rear compartment and the streetside compartment. It was cut a little short! I screwed a 1/2" x 1" strip on the partition and it fixed the problem.
I can scratch two more items off the list!! Pictures to follow.
2016 Flying Cloud 26u
2006 2500HD Duramax 4x4 new injectors (ouch!)
Equalizer Hitch
Banks 6-Gun
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 08-19-2016, 01:06 PM   #2
Southlake , Texas
Pictures
Here are the pictures.
ID:	269464   Click image for larger version
Equalizer Hitch
Banks 6-Gun
Southlake, TX
WBCCI
2016 Flying Cloud 26U TG2500 2016 - Current Flying Cloud 290 12-24-2016 12:17 AM
A/C problem in new 26u Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-25-2016 03:27 PM
26U Macerator Toilet - What do you think? Plan-B Sinks, Showers & Toilets 37 03-30-2016 07:39 AM
New 2016 26u Trees01 Member Introductions 1 01-17-2016 11:01 PM
26U Floorplan is Sweet! Bewell Airstream Lifestyle 1 09-25-2015 07:30 PM
