Old 03-05-2018, 06:59 PM   #1
2017 22' Sport
2018 26' Flying Cloud
Brighton , Michigan
TST TPMS Repeater Wiring
Going from a single axel (2 sensors) with no need for the TST TPMS repeater, to a 26 RBT that will have 4 sensors and 2 axels, so will be getting the repeater with 2 additional sensors.
Question for the many of you that use this system is how/where to you mount the repeater?
Second question is how do you wire it to the battery(s), also going from 1 acid battery to 2 glass matt batteries?
Last question, if left hot with no shut-off switch, will it drain the batteries any worse than the propane detector? Does the repeater have a sleep mode that it goes into after a period of no activity?
Thanks in advance for your insights and expertise.
Rivet Rocket is offline   Reply With Quote
Old 03-05-2018, 07:31 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I have a Tire Minder system complete with a booster. I mounted the booster in the battery box and wired it directly to the battery so it does draw constantly but I also have a solar system that is on all the time so it does not have any negative impact on the batteries. You can wire yours to a hot wire that is controlled by the main battery switch and avoid the drain issue. The Tire Minder System has not been trouble free and is actually a pain because something is always going wrong from bad sensors to a bad main monitor. I would now not recommend the system although I sure found it helpful when it was working. Booster has been flawless. Jim
Jim Flower is offline   Reply With Quote
Old 03-05-2018, 08:17 PM   #3
2016 26' Flying Cloud
Southlake , Texas
I mounted mine on the battery box and hooked directly to battery. I am always either on shore power or towing so battery drain is not an issue.
I also have TST and it would work without repeater unless I had my Garmin RV 760 on the dash and it would keep the TST from getting a signal to the monitor. No problem after installing the booster.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 03-05-2018, 08:20 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I mounted my rear camera repeater and TST repeater in the battery box. Hot wired directly.
MICHAEL
Old 03-05-2018, 08:35 PM   #5
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I tow with an SUV. I tucked the repeater under the edge of the headliner next to the rear window. I power it from an already-present 12V power outlet, and plug/unplug it manually.
I have a 25FB and I found that the TST 507 external units on my trailer are detected by the receiver even without using the repeater. I use the repeater anyway because I already have it.
SSquared is offline   Reply With Quote
Old 03-06-2018, 09:12 AM   #6
jamieb1086's Avatar
2016 25' Flying Cloud
Oradell , New Jersey
I have a 25' flying cloud with a TST system without a repeater and it works fine. You might want to try using it without the repeater first and if it works ok you can save yourself the trouble of hard wiring the repeater to the battery.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 03-06-2018, 09:36 AM   #7
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
TST Repeater
Although you didnít ask this question - we found that a repeater was unnecessary for our FC 30.
gsmithii is offline   Reply With Quote
Old 03-06-2018, 10:20 AM   #8
Mollysdad's Avatar
First I'd try it without the repeater.
Then you have a couple options. Mount it on the trailer or on the TV. How about outside the propane cover, or in the back window of the truck?
I'd make a way to disconnect it so it does not drain the batteries.
Old 03-06-2018, 10:51 AM   #9
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
TST Repeater Mount
Here is how I mounted mine-have the new color monitor-great TPMS from TST.
Easy process.
Inside the Propane cover with velcro.
Wrapped the wires around the tank holder in case the velcro failed(unlikely but you never know).
Wires out from bottom of the propane cover and through the hole already there in the battery compartment.
Attached small battery clamps bought at auto supply store.
Easy to attach/detach if worried about battery drain.
Works great.
Name:	TST repeater 1.JPG
ID:	305820   Click image for larger version
Name:	TST repeater 2.JPG
Silverbee is offline   Reply With Quote
Old 03-06-2018, 01:42 PM   #10
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
When we bought our TST it would drop one or more tires right at about 50 miles into the drive but not in a pattern and it did it on both trailers. I sent it back to be checked out and they replaced the head unit. I've been on several trips in the 28' since then and it has worked perfectly each time without a repeater. It now will pick up both trailers when parked and the Minuet is over 100' away in the back yard.
I have several friends who have them on larger Airstreams without a repeater and they work fine. Try would it first without and see if it works before you go to the trouble of installing one.
President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath, 1978 Argosy Minuet 6.0
2013 Toyota Tundra
rvb is offline   Reply With Quote
Old 03-06-2018, 05:15 PM   #11
Cumming , Georgia
TST TPMS Repeater
Hi All,
Thank you for all the great responses. I would wire the repeater right to the battery in the front of the trailer, Red Wire goes to positive, Black is Negative. Some use alligator clips, other wire directly to battery. Either is fine. Once the repeater has power it will glow red, and flash occasionally. The repeater has an in-line fuse, and draw is very low(a few milli-amps). Once connected just close up the battery box, and no need to worry about it.
As always if anyone has any questions I am always available at 210-420-0132
Thank you!!
Mike Benson
210-420-0132
PS: Our new Full Color Wide Screen Display is becoming very popular in the Industry, it does work with all existing 507 sensors.
mbenson1234 is offline   Reply With Quote
Old 03-06-2018, 05:29 PM   #12
2017 22' Sport
Brighton , Michigan
As the OP thanks to all that responded, great ideas and solutions.
My 22 FB had the exact conditions that RVB listed and I figured it was dropping the signal with no repeater. Therefore the decision to buy the repeater for the 26 RBT.
Will try with the repeater in case it is a defective head unit, signal will still drop after a short drive and I can contact TST.
Good to see that the National Sales Manager for TST reads these threads, they make a great product and care about their customers.
Old 03-06-2018, 05:35 PM   #13
2017 22' Sport
Brighton , Michigan
Originally Posted by mbenson1234 View Post
Hi All,
Thank you!!
Mike Benson
210-420-0132
As the OP I was pleased to see you post. Ordered the additional parts from Peggy in your office yesterday. Shipping confirmation today and she also sent a PDF of instructions as she promised. Well done, excellent service.
Old 03-07-2018, 08:58 AM   #14
2012 30' Classic
Homosassa , Florida
Repeater Location
I mounted ours on the power jack and ran the wires under the frame and got power from the same wire the power jack is getting power from. Make sure you install a fuse in the line. Lots of places for ground wire to attach using existing bolts.
Tater is offline   Reply With Quote
TST 507 TPMS Repeater Question Ridgerunner3 Tires 12 12-29-2016 12:23 PM
Tire Minder or TST TPMS for 30' FC Beach Bum Tires 8 02-05-2015 12:25 AM
Voyager interferes with TST TPMS SteveSueMac Lights - Interior & Exterior 11 12-09-2014 08:03 AM
Tst tpms SilverEagle6 Tires 6 08-09-2014 06:22 AM
TST TPMS fit and repeater SteveSueMac Tires 6 08-17-2013 12:29 PM
