Old 02-19-2016, 10:21 PM   #1
2016 27' Flying Cloud
Dade City , Florida
Unhappy Toilet Clearance
We just purchased a 2016 Flying Cloud 27FB and have discovered that the toilet sits too close to the sink. I have to turn to the side to sit on the throne.
Anyone else having this issue? Any suggestions?
Ernster is offline   Reply With Quote
Old 02-19-2016, 10:48 PM   #2
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I turned mine to face a bit more toward the door.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is online now   Reply With Quote
Old 02-19-2016, 11:05 PM   #3
Dade City , Florida
How did you do turn it? Any words of wisdom?
Old 02-20-2016, 11:53 AM   #4
1998 30' Excella 1000
Livingston , Texas
I don't know what type of toilet mounting flange the new rigs have, but here was how I could move mine.
Unscrew the toilet mounting nuts. Lift up the toilet. Move the mounting bolts to the next slotted holes in flange, if available. If not, remove the screws that hold the flange to the floor. Rotate the flange (it screws onto the tank). If it is too tight to rotate, you may have to make a tool from a 2 x 4 and two lag screws to get enough leverage.
Your rig may differ from mine.
Siegmann is offline   Reply With Quote
Old 02-20-2016, 12:49 PM   #5
Senior Member
sheriff1's Avatar
Sparks , Nevada
Unscrew the toilet mounting nuts. Lift up the toilet. remove the screws that hold the flange to the floor (8 I think) Rotate the flange (it screws onto the tank). I used the mounting bolts with fender washers and a nut snugged down on the flange. I used a 2' pry bar between the two bolts to slightly tighten the flange (clockwise). You don't need to move it much. Best done with holding tank dumped and rinsed!
Old 02-21-2016, 07:29 PM   #6
Dade City , Florida
Thanks for advice!
Old 02-21-2016, 07:29 PM   #7
Dade City , Florida
Thanks!
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 05:41 PM
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 01:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 07:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 04:52 PM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 12:03 PM
