Old 09-30-2016, 03:57 PM   #1
2017 27' Flying Cloud
BOERNE , Texas
Surge Protector on Elec Post or Built-in?
Friends,
I'm taking delivery of our 27' FC FB in a few weeks. We want a great surge protector. We currently use one (in our current AS) that plugs into the Electrical post in the camp. We wonder if having one wired inside the new trailer makes sense? Appreciate your thoughts.
BoerneBrogan is offline   Reply With Quote
Old 09-30-2016, 04:05 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Originally Posted by BoerneBrogan View Post
Friends,
I hardwired this one into my 28'. http://www.bestconverter.com/EMS-HW3...l#.V-7hEpGZORt
I like the convenience of not having to carry the external one and not worry about theft.
It was easy to access the back of the power center for installation. If I remember correctly the 27 may be more difficult.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-30-2016, 04:11 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
They eventually fail. Same for the auto formers. The latter may spark and smoke when it dies. The former?
After a few of those reports I decided I'd rather have them outside.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 09-30-2016, 05:16 PM   #4
RxGuy's Avatar
2010 27' FB International
Fenton , Michigan
I bought this one:
http://www.progressiveindustries.net/ems-pt30c
If you have a hardwired surge protector and it malfunctions, unless you have a bypass of some type you are out of luck.
External one malfunctions.....just plug your trailer in.
RxGuy is offline   Reply With Quote
Old 09-30-2016, 06:14 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I use and like the one that plugs into the pole. I decided it was just too much hassle to wire one in.
Old 09-30-2016, 06:15 PM   #6
white laker's Avatar
2002 31' Classic
lanark , Ontario
I beleive if either one of them fail, you have had a serge and they have done their job. You can unplug the fried portable one and maybe the root cause of the failure has passed........... or not. You should know for sure shortly after you reconnect your unprotected trailer.
Both systems have their pros and cons. Have a good look at both.
Pete Crook
"Put it all behind you!"
white laker is offline   Reply With Quote
Old 09-30-2016, 06:31 PM   #7
2015 30' FB FC Bunk
Ayer , Massachusetts
I have a hard wired unit and love it. Haven't had problems though. The dealer installed it prior to delivery.
Ted S. is offline   Reply With Quote
Old 10-01-2016, 11:34 AM   #8
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Pt30
Think twice about hardwiring. I use the portable PT30 from progressive and have a piece of mind. I use a check list on setup and packup. Like one poster mentioned if unit is hardwired and smokes then what do you do? Great question.
Regards
Mike
mcomeaux is offline   Reply With Quote
Old 10-01-2016, 12:02 PM   #9
Lkjdude's Avatar
2015 25' FB Flying Cloud
Nebo , North Carolina
Surge protector.
I also bought the Progressive Industeries 30amp surge protector. Works fine on shore power and my Honda generators. I really like it, easy to use.
I ran electrical wire and a water line for a shore power outlet when I built a shed for my airstream. 270 feet from the my home. Then I plugged in the surge protector just to be shure everything was as it should be. Voltage was what I had calculated and everything else checked good also.
Lkjdude
Lkjdude is offline   Reply With Quote
Old 10-01-2016, 12:08 PM   #10
Watertown , Massachusetts
Hardwired Progressive
We have a hardwired Progressive Industries unit. Since we are "belts and suspenders" type of people, we also invested in spare boards for the unit. There are three boards in our unit (30 amp) and we have a spare of each. That way if there is a failure, we can just call them and they will walk us through the diagnostics to determine which board blew and we will replace it right then.
sallye is offline   Reply With Quote
Old 10-01-2016, 01:14 PM   #11
2015 30' International
FREDERICK , Maryland
Go portable
If your hard wired in unit fails, then you have NO power at all. If a portable one fails (or in both cases, either one fries because it did its job), then you just buy another one, and until you do, you can still get unprotected power.
Something like this
http://www.campingworld.com/shopping...r-50-amp/56424
or
http://www.campingworld.com/shopping...y-30-amp/81277
Get the appropriate size 30 or 50 amp.
Doc Foster is offline   Reply With Quote
Old 10-01-2016, 01:45 PM   #12
Bypass switch
Re: "If your hard wired in unit fails, then you have NO power at all."
Well, actually, that isn't always true. On the unit we have there is a bypass switch. You just flip the switch and it bypasses the unit. Then you have power again but no surge protection until the unit is repaired - depending on which board failed. I'm guessing not all manufacturers / units have this switch. So, maybe that is something to we aware of while you are shopping
Old 10-01-2016, 01:46 PM   #13
Full Timer
2006 28' Safari S/O
Newport , North Carolina
Note that the Progressive external units (which seem to be the very best of their kind available) each have a robust collar with an eye, allowing you to secure the unit to the power post to discourage theft.
Michael
mpawilliams is offline   Reply With Quote
Old 10-01-2016, 01:58 PM   #14
Adventure.AS's Avatar
2017 25' International
Port Dover , Ontario
Surge Protector By-Pass
There is a simple, low cost solution if the hard-wired surge protector fails. Progressive has a by-pass switch for about $25 that allows you to go into ByPass mode without opening the unit.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
