Old 09-01-2019, 08:47 PM   #1
Squeaking Floor
Picked up 2020 FC 27FB 2 weeks ago and the floor around the bed squeaks when standing on it. I already have plan on returning to the dealer next month for other issues.
My question is there something that can be done to make the floor quite?
lzhome is offline   Reply With Quote
Old 09-01-2019, 09:03 PM   #2
2004 16' International CCD
2019 27' International
Cheyenne , Wyoming
Try loosening and maybe retightening the screws in the molding between the wall and floor. Try various adjustments on loosening and tightening the screws.
That will usually resolve the squeaking for a few days and then you get a new squeak in a different area. Then repeat.
Wyo Silver is offline   Reply With Quote
Old 09-03-2019, 03:42 PM   #3
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi lzhome,*
Congratulations on your new Airstream and we're very sorry to learn about the issues you are having. Please don't hesitate to reach out to us and send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 09-03-2019, 04:05 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The solution is most likely to take some silicone spray, and spray the vinyl edging at the base of the wall. You can also loosen the screws holding the vinyl edging, which should also help.
Old 09-03-2019, 05:30 PM   #5
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Took our 2017 25a FC to JC a few months ago for warranty work including a squeaking floor between shower and bed. Whatever they do, it worked. Solid floor with no squeaking whatsoever after JC fix.
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 09-09-2019, 01:29 AM   #6
Night owls's Avatar
2018 26' Flying Cloud
Hemet , California
As others have mentioned. Try loosening the molding between floor and wall and that should resolve it. Mine had the same issue around the bed and fixed after I loosened it a bit.
Night owls is online now   Reply With Quote
Old 09-09-2019, 05:46 AM   #7
lmk
lmk's Avatar
2018 30' Flying Cloud
Georgetown , Texas
Same as HHPJ. My very loud squeak was curb side between bed and window. Dealer fixed it under warranty. Not sure what they did.
2018 Flying Cloud 30RB
2018 Ford F150 5.0L V8
lmk is offline   Reply With Quote
Old 09-09-2019, 06:29 PM   #8
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
Am at Jackson Center in the Terraport as I type this. The noisy floor was the main item on our punch list prior to going out of warranty and the tech did as described above. So far it's quiet. I thought he'd have to drop the bottom off the trailer, remove the black tank, and get to the point where the plywood is attached to the frame outriggers to fix the noise. Luckily that wasn't required.
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 09-23-2019, 08:20 AM   #9
Thanks for the responses. I have a dealer service appointment in 3 weeks so I'll wait and let them figure it out.
Old 09-24-2019, 06:24 AM   #10
lmk
lmk's Avatar
Georgetown , Texas
Baby Powder
Just found out dealer used baby powder to fix mine. First day on the road after fix I noticed quite a bit of powder along floor under bedroom window...where squeak was. Assume they loosen flooring and pour it in area. It worked.
2017 Classic Floor Squeaking, Anyone else? OSIN 2016 - Current Classic (all lengths) 32 08-22-2018 09:24 PM
Squeaking Floor Pat Cassity Repairing/Replacing Floor &/or Frame 34 10-09-2016 05:23 AM
Brakes squeaking on 2012 Classic ? Airtrekker 2011 - 2015 Classic (all lengths) 1 07-25-2016 07:23 AM
Microwave Squeaking/Rattling Solution migriffin Sprinter and B-van Forum 8 06-30-2015 10:39 AM
Squeaking Drums? rambn Brakes & Brake Controllers 11 05-22-2007 02:57 PM
