03-13-2019, 09:52 PM
#21
2002 19' Bambi
Lafayette
Originally Posted by Mount'n Man
So, I've been working on a scare light cover for our '06 (old style porch light fixture). I think it will work just fine... ~$15 total investment Attachment 335423
So where did you find that great looking stainless cover?
Tim
03-14-2019, 07:53 AM
#22
Cedarcreek
, Missouri
03-14-2019, 07:56 AM
#23
Cedarcreek
, Missouri
03-14-2019, 08:05 AM
#24
2017 25' Flying Cloud
Fayetteville
, Arkansas
Direct install over the existing scare light fixture?
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
03-14-2019, 09:09 AM
#25
Cedarcreek
, Missouri
Had to remove the 3 self tapping screws from the original bezel, but the light fixture isn't going anywhere (well caulked to the trailer). Picked up some SS flat head sheet metal screws and was going to countersink the bezel but decided against it. The automotive trim tape covers all completely. May run a bead of urethane caulk around the outer edge later to insure against water seeping in.
With the LED replacement bulb in the fixture, I don't expect to have to remove the cover in my lifetime.
03-14-2019, 10:21 AM
#26
2016 16' Sport
Port Angeles
The 4.7 inch?
03-14-2019, 11:13 AM
#27
2018 26' Flying Cloud
Thornton
What diameter did you use? 4” or 4.7”?
03-14-2019, 11:24 AM
#28
2002 19' Bambi
Lafayette
Thank you!
Tim
03-14-2019, 12:53 PM
#29
Cedarcreek
, Missouri
The 4.7" model. Actual O.D. of the item is 5.75" which fits nicely over the old style bezel, and with the bezel screws removed and a single layer of the adhesive tape, it fits to just touch the side of the trailer. Only drawback is that the bezel screw holes line up with the crease in the cover, hence the need for the automotive trim adhesive tape.
03-14-2019, 02:56 PM
#30
Thornton
[emoji1303]Thanks much!
03-20-2019, 12:28 PM
#31
2019 25' Globetrotter
Nashville
, Tennessee
Ordered this, it was dented upon arrival but I’ll happily order another. I sure wish I’d worn gloves, I wouldn’t have so many blood stains from the very thin metal going right through my pinky!
'18 RAM 2500 Laramie, Cummins
'19 Globetrotter 25FB
03-20-2019, 05:00 PM
#32
2016 26' Flying Cloud
London
, Ontario
Did you order the fixture MountainMan recommended? If so, and you plan to put it over a newer scare light, I might be able to give you some help. I just did mine. Not for the faint of heart!
You're a long time underground!
03-20-2019, 06:35 PM
#33
Thornton
My also arrived with a dent. I was able to pop the dent out with my thumb...mostly. It was easy. Try it, yours may pop out cleanly.
07-25-2023, 12:00 PM
#34
2013 25' Flying Cloud
Wheaton
On my trailer, the stove vent is directly above the light.
I am considering replacing the bottom screws holding the vent to the trailer with snaps so that I could snap on a cloth to cover the light and diffuse the bright beam.
Greg
