Old 07-25-2016, 09:24 PM   #1
2005 30' Safari
Oak Park , Illinois
Running AC while using convection microwave
We have a 2017 25FB with 30 amp electrical service, 15000 btu AC, and convection microwave. This weekend, with temps in the mid nineties, my wife exclaimed there must be a way to keep the AC running while using the convection oven. The break throws when she tries to run both. This is our second Airstream with similar setup and the same power challenge.
Any insight we may have not considered?
She likes the convection microwave over the gas oven.
FishByFly
because I catch fish on a fly...
2005 30' Safari Bunkhouse
2010 F250 Lariat
FishByFly
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 07-25-2016, 09:34 PM   #2
2007 22' International CCD
Nothing other than an upgrade to 59 amp, or a completely separate 20 amp power cord to the pedestal for the microwave.
30 amps is 30 amps, and that's all you can push through the wire....without breaker popping or a meltdown.
KE4GNK/AE
Old 07-25-2016, 09:59 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Repeated breaker popping can damage the items it powers.
On our 1999 we ran on 30 AMP... AC and MW/conv ... We had to shut off the electric water heater, fridge on to propane and shut off the converter. Only power draw was MW and AC.
That was unacceptable. Especially Texas summer heat on our 34' and one AC.
I upgraded to 50 Amp...
Installed AC 2,
my Bride can turn all the electrics on and no "popping" breakers.
I know... I learn so slowly... But, Bride can crank AC however cold works for her.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-01-2016, 10:30 PM   #4
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
I bought a power cord with plug that can be placed between the Airstream and the 30 amp socket that read amps and watts. This way you can see what appliance draws what. The AC will use about 11 amps. The microwave about the same. Also, the electric water heater is close to the draw of the AC. You can run the AC and the microwave on 30 amps together if only gas water heater. But, you have to watch you don't ask to run something else, like a hair dryer!
rp709 is offline   Reply With Quote
Old 08-02-2016, 11:24 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I have this mod:
http://www.airforums.com/forums/f37/...0v-119935.html
Which allows me to see what's going on.
Typically, yes, you can run them both at once, but:
1) You must shut off everything else, including the fridge (put it on gas) and possibly the converter
2) You have to put the air conditioner fan on low, which reduces the current draw by a few amps.
3) You have to have good voltage at the campground, because if the voltage is low, the air conditioner will draw more amps.
On a "30a" service you're supposed to be able to draw 24 amps continuously without tripping a breaker. I sometimes push it a little but figure anything over 26 amps is risking a trip.
Old 08-03-2016, 10:07 AM   #6
2007 27' Classic FB
Ridgefield , Washington
Images: 8
Anytime we run the A/C, the water heater and fridge go on propane. Breaker didn't always trip but it is less of an inconvenience to put the two appliances on propane.
John & Lisa
Woosch is offline   Reply With Quote
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Swap stove for convection microwave? cosmotini Stoves, Ovens & Microwaves 13 01-21-2015 09:02 AM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Inverter sizing for factory convection/microwave oven? myoung Electrical - Systems, Generators, Batteries & Solar 11 10-03-2005 07:24 PM
Stove.. replace with convection microwave? Happycampers Stoves, Ovens & Microwaves 9 08-22-2003 06:06 AM
