Old 11-07-2016, 02:59 PM   #1
cstevecook's Avatar
2017 23' Flying Cloud
Gaithersburg , Maryland
Rodents
Should I worry about rodents getting into our 2017 FC? If so, what are some recommended preventive measures?
Steve
cstevecook is offline   Reply With Quote
Old 11-07-2016, 03:12 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Depends on where you live. I have sealed up all the exterior holes I could find using HVAC Aluminum tape. So far so good.
MICHAEL
Old 11-07-2016, 03:31 PM   #3
The Myth
Killeen , Texas
http://www.mouse-free.com/a/pdf/flyer-front-oct2014.pdf
JPAS is offline   Reply With Quote
Old 11-07-2016, 04:30 PM   #4
Lexington , South Carolina
Since bottom is fully covered with a sheet of metal, I don't know how they would get in, much easier with other brands.
SCbarber is offline   Reply With Quote
Old 11-07-2016, 04:35 PM   #5
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
apparently a mouse can get through a hole the size of a pencil eraser . . . sounds hard to believe but that's what I've read . . . and I had an entire city of mice living in between my walls with no obvious way to get in except very small holes . . .
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 11-07-2016, 04:46 PM   #6
Kevin245's Avatar
Mice can squeeze through the smallest of openings. Even the slightest gap in the belly skin can afford them access to your rig. The A-Frame (tongue) tubes are a vermin highway if not sealed.
William C. Swinney
Old 11-07-2016, 05:56 PM   #7
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
It's been years, but had a mouse get into our trailer while it was hunting camp. The mouse apparently squeezed through a spot on the underbelly that was hanging less than a quarter inch. The metal almost completely severed one of his hind legs. That little guy traveled over almost every inch inside our trailer before succumbing to the massive blood loss and died right beside the kitchen sink. The clean up was no fun.
1973Argosy is offline   Reply With Quote
Old 11-07-2016, 06:33 PM   #8
cstevecook's Avatar
Rodents
It sounds like Hvac aluminum tape is the best bet. What areas underneath are best to seek out other than the A frame penetrations?
Steve
Old 11-07-2016, 06:48 PM   #9
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Yes
[QUOTE=cstevecook;1873810]Should I worry about rodents getting into our 2017 FC? If so, what are some recommended preventive measures?
Yes. Plan on it, be proactive on Mouse Deterrents. Take your choice between Snakes, Total submersion, High Tension Power current, Cryogenics, Vacuum Chamber, Mice killing ants, Killer Bees, Cannibal Mice, Cyanide, Crazy Cousin Earl, Loud tape of Blondie, Moth Balls, Yellow One Bite packets, Bounce sheets.
I find the One Bite to be very effective but not so good if you have dogs and cats. Moth Balls can be effective. Not too sure about Bounce Sheets, some folks say they work. The bottom of your machine will have a hole somewhere, that you can't find but Mrs Mouse knows where it is.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 11-07-2016, 06:53 PM   #10
Kevin245's Avatar
Steve
The foil tape will help close gaps. To seal holes though I use stainless steel wool.
https://www.mcmaster.com/#7364t76/=14xy112
William C. Swinney
Old 11-07-2016, 06:54 PM   #11
Kevin245's Avatar
Look for any gaps in the belly skin and seal even the slightest gap where penetrations occur.
William C. Swinney
Old 11-07-2016, 06:56 PM   #12
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
While I don't have a lot of experience dispatching rodents, I do notice there is an advertisement for a Kimber 9mm semi auto pistol to the right of the threads. Coincidence?
Mike
Caffeinated is offline   Reply With Quote
Old 11-07-2016, 07:14 PM   #13
cstevecook's Avatar
Caffeinated needs to back off on the Java!;-)
Steve
Old 11-07-2016, 07:32 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The "A" frame along with wheel wells are easy entry points. The shore power cable if it has inside storage and is connected permanently to the coach.
If you have ever seen a ship moored at a dock. You will notice a disk shaped device on all mooring lines. This is to prevent mice and rats running up the line and onto the ship.
I have such a disk on the shore power cable of my 2 travel trailers.
Keep the weeds down and the underbelly free of debris.
Old 11-07-2016, 07:34 PM   #15
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Airstreams are mice luxury hotels. They love'em. I acted like Daniel Boone the fur trapper and set up a snap trap line in my trailer every winter. I think my record was 8 mice.
Certainly seal up the A frame channels under the coupler up front. The rear bumper storage compartment is a "welcome here" access point for the little critters. I also had access points at the propane lines, wheel wells, and belly pan seams. Even the folding entry step "slots" are good entry holes that I couldn't figure out how to seal up.
Here is a mouse carcass I found in my freshwater tank pan. This guy died from old age. Probably lived down there for a long time. I hope he enjoyed our camping trips. That bad smell wasn't the dog after all. Sorry doggie.
David
Name:	1610 Fresh Tank Pan Mouse.jpg
Old 11-16-2016, 01:27 PM   #16
cstevecook's Avatar
Thanks for the advice. In addition to removing all food, bedding etc. I found several small openings in all the places mentioned except the step area. I used stainless steel wool to fill gaps and then taped openings and seams with foil tape.
Steve
Pesky rodents 2-roamers On The Road... 19 10-19-2013 07:51 PM
Protect your cornhole bags from rodents yakman On The Road... 24 07-18-2010 06:33 PM
Rodents in Tradewind lanajane General Repair Forum 2 06-27-2007 09:50 AM
Prevent rodents, ants in trailer. Ed Keyes 2001 Safari 3 09-12-2003 01:38 PM
How to keep rodents on the outside jtetzlaff General Repair Forum 2 01-06-2003 07:19 PM
