Old 06-12-2019, 10:37 AM   #21
Colorado couple
2018 23' International
2015 Interstate Grand Tour
Colorado Springs , Colorado
WD hitch
I pull a 23 FB with a Cayenne diesel. I use an Equal-i-zer 1000 lb hitch. It has worked great, especially if you get the plastic plates for the sway bar mount to get rid of the “groaning”.
Vabound is offline   Reply With Quote
Old 06-12-2019, 11:15 AM   #22
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by DWL View Post
Thanks for all of the input. We ended up buying the Equalizer hitch
Wayne
Wayne,
One thing if you would like to check, make sure the hitch ball shank is the correct length. I’ve replaced two hitch balls on the newly installed dealer fitted Equal-I-Zer hitches where the long shank interferes with the trunnions as they turn thru their range.
Simple inspection. Any witness marks on bottom of shank in an arc pattern? Or shank projects below bottom of hitch head. It is noticeable.
It’s a stout hitch. Correct length avail at equalizer or I found at tractor supply also.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-12-2019, 12:49 PM   #23
patterson , Louisiana
Hi
If you have any WD hitch .... take a look at the little bits and pieces associated with it. On the Equalizer there are "hair clips" on the pins that hold the bars to the hitch (and the pins). There are also the little right angle things that lock the bar to the trailer.
You may be perfect and never ever loose one of any of them. That's not a good thing to depend on. Buy a couple of spares of each and put them where you can find them. Finding that this or that has gone missing just as you are about to pull out ... no fun at all.
I'm looking for a place to buy the "hair clips" for the Equalizer pins in bulk ...
Bob,
Try what i did: Tie a 6 inch or so piece of nylon string to each pin, and paint each one with RED NAIL POLISH if (when) you drop it it is easy to find in the gravel or grass. BINGO.
Same with the "L" shaped brackets, pain them as well. I never lost any!
CCC
Carmelo
Charles C Culotta, Jr.
SUPPORT OUR TROOPS
carmelo is offline   Reply With Quote
Air Safe Air Hitch and WD hitch combo JBCrete2 Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
