Old 04-12-2016, 09:49 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Need picture of 26u
I think my new AS is missing a/c temp sensor in Zone 2 (bedroom). If you either own or have access to a 26u and can take a picture of sensor and post it, I would sure appreciate it. I am told that it is located on wall near TV.
Bgibbs is offline   Reply With Quote
Old 04-13-2016, 06:59 PM   #2
LilBigfoot's Avatar
London , Ontario
Sorry, can't help you... Only one AC and no sensor in our 26U.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 05-06-2016, 10:26 PM   #3
Southlake , Texas
After 1 trip to the dealer and several calls to AS, I was finally told that the missing sensor is supposed to be under the curb side overhead storage. Taking trailer back to dealer next week for second attempt at fixing this problem.
Old 05-15-2016, 11:38 PM   #4
niceville , Florida
So did they fix it, ? What does the sensor look like?
kapt59 is offline   Reply With Quote
Old 05-18-2016, 09:54 AM   #5
Southlake , Texas
It has been back at the dealer for a week and a half for the repair. First, they had to get plans/drawings from AS showing where the sensor is "supposed to be". Then they had to order a sensor which was supposed to arrive yesterday. I have not heard anything. The latest story I get from AS is that the sensor is to be mounted on the underside of the overhead storage in the bedroom on the curb side. It is the same sensor used on all the current AS models. White, about the size of a silver dollar with slots cut in it. The actual sensor is mounted behind the white grill.
Old 05-24-2016, 07:52 PM   #6
niceville , Florida
did they fix it all for you?
Old 05-25-2016, 01:43 PM   #7
Southlake , Texas
It's finally fixed
The mystery sensor has been installed. The only complaint I have is that the tech walked on one of the beds and left boot prints on the sheet. Oh well, we were going to wash them anyway. I tried to rotate photo and no matter what I did, this is what I got. This is on the curb end of the rear overhead in the bedroom.
Old 05-25-2016, 11:46 PM   #8
niceville , Florida
ok, i am confused? u have 1 a/c system or dual? isn't the sensor in the thermostat system already?
Old 05-25-2016, 11:48 PM   #9
niceville , Florida
okay disregard, went back and re read the post..........and i have a 26u also, dual ac system, and i don't recall seeing that gadget either?
Old 05-27-2016, 12:46 PM   #10
Southlake , Texas
Just check the inside temp with the a/c or heat on and make sure both readings are reasonable close to the same. I set my a/c to 75 deg and ran until both units shut off. Inside temps were reading the same front and rear. Before the repair, the front would read 75 and the rear could read anything and the rear air would never shut off. I can't believe that they would forget two of them! Well, maybe I can.....
Old 07-08-2016, 03:52 PM   #11
niceville , Florida
I finally went to the factory. Asked about my second sensor. Turns out the same as yours.
Instlalled somewhere between outer and inner skin.
They found the lead, cut and replaced harness and sensor.
Placed it in aft bedroom .
Old 07-08-2016, 04:40 PM   #12
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Where is the sensor for zone 1 and what does it look like? I have a 2016 FC FB and I think I am missing a sensor also.
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 07-08-2016, 07:33 PM   #13
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
The sensor for Zone 1 in the CCC units is integral with the thermostat. At least it is in my '15 Classic. Zone 2 is the remote sensor noted above, and is in the same room with the 2d A/C.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
2016 Flying Cloud 26U TG2500 2016 - Current Flying Cloud 390 11-21-2017 10:29 AM
26U Macerator Toilet - What do you think? Plan-B Sinks, Showers & Toilets 39 07-12-2017 04:07 PM
A/C problem in new 26u Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-25-2016 03:27 PM
New 2016 26u Trees01 Member Introductions 1 01-17-2016 11:01 PM
26U Floorplan is Sweet! Bewell Airstream Lifestyle 1 09-25-2015 07:30 PM
