Old 05-09-2018, 01:09 PM   #21
2013 25' FB Flying Cloud
Scotts Valley , California
Originally Posted by SteveSueMac View Post
Which jack do you have specifically? I don't think that would work in the crank of my jack but would be willing to try it if we have the same one (mine's on the 2012 27FB Flying Cloud). Thx!
Here is the handle installed with the 6" extension
25Twin is offline   Reply With Quote
Old 05-18-2018, 12:57 AM   #22
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
The positive lead to my power jack got squashed by the propane bottle cover. Airstream had routed this along the frame at the front edge of where the cover would normally sit. The fuse is after that point, close to the jack motor. This event fried the wire to the battery! Scary. I was dropping the trailer at the Airstream dealer when I found the jack not working, to unhitch. So I had them install a fuse adjacent to the battery + post. This is where a fuse should be; not after the wire can pass along the frame and ground. Airstream corrected this on later models, relocating the fuse; according to the dealer. My trailer is a 2015 Flying Cloud 30.
50 AMP Dual AC
AM Solar 570 watts
2 Golf Cart 6V Batteries
2012 GMC Denali HD Duramax
Pro Pride hitch
rp709 is offline   Reply With Quote
In Line Fuse for LP Gas Detector mikeljla General Repair Forum 21 06-04-2022 09:24 AM
50 amp buss fuse line install which one? Mx468 Batteries, Univolts, Converters & Inverters 4 01-09-2017 08:14 PM
Help installing in-line fuse holders? anf6k Electrical - Systems, Generators, Batteries & Solar 5 05-18-2013 09:06 PM
In-line fuse with switch adonh Electrical - Systems, Generators, Batteries & Solar 2 11-24-2007 04:52 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
