Old 09-20-2017, 09:53 AM   #1
2017 25' Flying Cloud
w.springfield , Massachusetts
Hiden inline fuse
Recently had the main inside lights fail . Fuse on main board was good and other devices on same circuit ,like the stove hood still worked . Figuring to circuit test starting with the switch . I popped off the cover plate and unscrewed the switch. From the cabinet . And stuffed in there is an inline 20 amp fuse. Wow real head scratcher ! Didn't see anything in manual about it . Of course now i worry why it popped for no reason ?
Every flying cloud has a silver lining !
mazoolah is offline   Reply With Quote
Old 09-20-2017, 01:15 PM   #2
Long Island , New York
Not sure . . . but I would pull down the light fixture closest to the circuit breaker, to see if the hot wire fell of the fixture's connection point, and to test voltage continuity at this location. If all the other light fixtures are fed off this first light, and the connection failed there, that would explain it IMO. [if I have understood this right? ]
Good luck and please let us know what you find.
Peter
PS -- That's what you get for letting go of the FC20. [humor . . . . . . ]
PS2 -- Removing the light fixture might be a real challenge if they are like our 2014 FC20. There are weird clips/springs which require a real tug down at some point. Maybe yours are different. I would search here in the blue box above for "ceiling light removal" to get some guidance. I found a thread or two last year, and will look if you want. Please advise.
Old 09-21-2017, 03:47 PM   #3
FYI this new thread may have some overlapping issues IMO:
http://www.airforums.com/forums/f447...ff-172972.html
Peter
Old 09-25-2017, 09:23 AM   #4
Its been working fine so far. Not getting any deeper into it than the fuse ,as is under warranty . Will put question to dealer when it goes in for service.
Online source for classic cars & more 83Excella Off Topic Forum 4 03-05-2007 09:02 PM
The Caravanner online Cruiser WBCCI Forum 3 04-06-2004 11:31 PM
West Coast Camp/RV Resource Online JodynJeep On The Road... 0 10-20-2003 04:40 PM
Currently online John Our Community 4 01-15-2003 08:11 PM
Vintage Airstream documents online Rog0525 Our Community 0 12-13-2002 02:11 AM
