05-27-2019, 01:15 PM
Tomball
Hair blow dryer and A/C or A/C and microwave
Can any of you having the 2016 FC 23ft use a hair blow dryer and A/C at the same time?? What about the A/C and microwave? I am still new at the camping and concerned about blowing a fuse or something. I do so appreciate the voices of experience.
05-27-2019, 01:30 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Do you run the DHW with electricity too?
Ray B.
05-27-2019, 01:36 PM
1986 31' Sovereign
Miami
Assuming you have 30 amp service, you probably should not run the a/c and either the microwave or hair dryer. It may work as long as the a/c doesn't cycle but, if it does, you'll almost certainly pop the breaker. I just switch the A/C to "fan" while microwaving then back on after I am done and would do the same if we owned a hair dryer.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
05-27-2019, 01:37 PM
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
Are you talking about on shore power or battery?
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
05-27-2019, 07:18 PM
1995 25' Excella
xxxxx
, xxxxxx
When hooked to 30A service, we often use the microwave when the AC is running. Never had an issue.
05-27-2019, 07:38 PM
2017 23' Flying Cloud
Bartlett
, Tennessee
We turn off the electric water heater element and the air conditioner when using a blow dryer. We use the air conditioner at the same time as the microwave.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
05-27-2019, 08:52 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Hair Dryer
We bought the Hair Dryer from a Forum Airstream recommendation. It works well does not draw the heavy amps.
Andis Gentle Dry 650 Low Watt Pet Dryer Durable
05-27-2019, 09:28 PM
Tomball
Using shore power.
05-27-2019, 09:29 PM
Tomball
Originally Posted by Life is a Highway
Thanks for the link. I'll certainly follow up on that.
05-28-2019, 06:57 AM
Tomball
Yes, when connected to shore power.
06-01-2019, 09:01 AM
2016 25' Flying Cloud
Vadnais Heights
This video is easy explanation to start with
https://youtu.be/bXiQhZkurL0
Try watching this short video that will help answer your question.
06-01-2019, 09:10 AM
1987 32' Excella
Nepean
, Ontario
FWIW, on the older AS, such as my '87 Excella, the a/c is on the same circuit as the microwave, but there is an A-B switch so that only the a/c OR the m/w can run. The other 15-amp circuit which has a GF breaker runs everything else - so any single higher powered item, such as a hair dryer or coffeemaker can be used.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
06-01-2019, 11:57 AM
Tomball
Very helpful. Thank you for sharing. That should answer not only my initial question but any others I may have. [emoji106]
