Your limiting factor is the battery state-of-charge. There is a parasitic drain from a number of control boards to run things like the carbon monoxide detector, refrigerator status, etc. It can last quite some time if your batteries are at full charge when you leave. A few days can be done easily if you ensure no lights or other systems (like the water pump) are left on. FYI, be sure to NOT place the battery disconnect switch in "Store" mode.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
