12-10-2018, 08:20 AM
2018 27' Tommy Bahama
Bainbridge Island
Found a nut sitting on the step
Hah hah! But no joke. Drove about 300 miles to our campsite last night, nothing unusual. When we pulled out the steps, found a nut sitting on the there. I would call it a flange nut, about the size of a quarter (including the flange).
I looked around the area where the steps stow for travel, but couldn’t find where it came from.
Judging from the size it looks important.
Maybe it was kicked up from the road? But seems unlikely.
Any ideas?
2018 27FB. Posting here because I think the steps are the same as my Tommy Bahama.
David
12-10-2018, 12:12 PM
2020 23' Globetrotter
Savoy
Looks like the nut that holds the shock absorber onto the stud.
12-10-2018, 12:33 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Those steps look like the same steps that are used on my 72, if so, the steps themselves wont use a nut like that anywhere, not even in the mounting.
If your trailer was an Airstream, (maybe it is, I don’t know), I might be inclined to think the nut fell from the belly pan onto the step while you were driving, and I might attribute it to a nut that was dropped and lost in the assembly process of the trailer.
That would be my best guess.
12-10-2018, 01:03 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
It looks like the nut on the bottom end of the threaded rod that holds the propane tanks.
I'll guess it was defective so tossed into the belly pan at the factory, then vibrated/bounced until it found it's way out.
Alan
12-10-2018, 01:43 PM
1972 31' Sovereign
Benton
, Arkansas
Or someone dropped it by mistake. (We should only assume the worst from professional politicians and other lawyers. )
(Look for the humor)
12-10-2018, 05:51 PM
Bainbridge Island
That was it. The nut on rear shock, curbside was missing. It must have dropped off going down the road, bounced, and landed on the step. What are the odds?
The nut on the bottom of the same shock was loose, but still there. The other 6 were snug. I put the loose ones back on, just snug, with thread-locker just in case.
12-10-2018, 06:16 PM
1972 31' Sovereign
Benton
, Arkansas
Impressive call SpinWhite.
Nice!!
12-10-2018, 07:23 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
For a minute, I thought you or my wife caught me sitting on the step ......sometimes you feel like a nut ....sometimes you don't ...
12-11-2018, 10:54 AM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Great Call
Great diagnostic evaluation. 👍
12-11-2018, 11:05 AM
2014 25' FB Eddie Bauer
Vero Beach
+1
I’ve had two shock absorber retaining nuts go missing. They are 1/2” stainless flange nuts. Lucky landing spot. They need a corresponding fender washer to be right. I bet that wasn’t next to the nut, eh?
12-11-2018, 11:12 AM
1975 27' Overlander
Galena
Play the lottery, your a lucky person not only for finding the nut , but then finding where it came from that could have had a catastrophic effect on you and yours. Safe travels.
12-11-2018, 11:47 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I worked in a firehouse for 30 years.
We had a couple of guys that would crawl around under a truck for hours to find where a nut laying in the floor under a truck came from, then argue about the solution.
I am not to proud to admit I may gave dropped one or two over the years just to watch the show.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
12-11-2018, 01:24 PM
2007 22' International CCD
Corona
One of the more fascinating sailboat racing ploys is to do the following:
Obtain a common used silicon bronze large Phillips oval head wood screw. Drill a pilot hole into a nice piece of mahogany. Partially run the screw in with a worn and damaged hand screwdriver, and bugger up the head a bit. Then take a large claw hammer, and pull the screw out of the wood, so it leaves splinters of wood in the threads. Keep this prepared screw in your pocket.
During a race, when you are rounding the final buoy close-hauled and upwind of your closest competitor, toss the screw into his sail, so it will silently slide down, fall off, and land on his deck with a bang. This will immediately give the skipper a start, and he will logically conclude that something has come adrift in his standing rigging, with imminent total failure, and dismasting not far behind.
He will immediately lose concentration on the race at hand, direct his entire crew to visually inspect ALL the rigging, and at that point, he will be completely out of the race... All you need to do at that point is to cross the finish line in an expeditious fashion.
12-11-2018, 08:37 PM
Bainbridge Island
I didn’t notice whether or not the washer was still on the bolt. Probably not. I will have to check in the morning and if necessary get a washer.
Anybody know how much to tighten the nut? I went about 1/2 turn past snug.
12-12-2018, 04:48 PM
Bainbridge Island
Originally Posted by GammaDog
+1
Not there, but found one easy enough at the hardware store this AM.
Should be all good now, but I will keep an eye on them for a while.
Thanks everybody!
12-12-2018, 07:35 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
Wow. Another hidden danger waiting to ruin my day. Now I have to add ‘checking shock nuts’ to my list.
12-14-2018, 05:46 AM
2019 Interstate Grand Tour Ext
Dallas
, Arkansas
Any ideas?
Attachment 329406Attachment 329407
David
Our steps failed on the first trip. One of the fasteners was loose and the bottom step collapsed. I found the parts but never trusted the bottom step and just avoided using it. That bolt in your picture was not part of our step assembly. Happy Camping!
12-14-2018, 07:06 AM
Airstream - Other
Bosque Farms
, New Mexico
Get to know your friend:
Lynn
ACI Big Red Number 21043
12-14-2018, 10:20 PM
Corona
Amen to that. Saves a lot of searching for replacement fasteners, but still can be unscrewed with ‘normal ‘ tools. The Red stuff is permanent.
12-15-2018, 07:05 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Regards,
JD
X2
I had a co-worker that would keep everything in a brownie pan during a repair...we never used anything so obvious as a common nut, washer or bolt. It had to be something that looked important but wasn't. Weird fasteners worked very well...we had many entertaining coffee breaks. 👍👍🥴
It stopped when a customer had to wait an hour, after closing, while he tried to determine where our joke went. 👎
"You don't know where you've been until you leave, enjoy life" RLC
