Old 01-11-2016, 03:07 PM   #15
2016 28' Flying Cloud
The Plains , Ohio
Originally Posted by m.hony View Post
Congratulations on your new trailer!
Hitch:
Pull forward, reverse, ever so slightly depending un uphill/downhill to release pressure- coupler will come right off the ball!
Internet:
You must either have a Wi-fi router or use your cell phone as a Wi-fi hotspot to use any internet features on the television- or use your Chromecast-
Generator input:
There is no generator input unless you have one custom installed. You can use the regular shore cord.
Equl-i-zer:
Grease it! Push grease into every joint, nook, cranny- everywhere you can get grease on the hitch head and get the Sway Jacket Brackets to cut down noise at the L-brackets.
Hope this helps.
Enjoy your trailer!
I have a WiFi Verizon internet hotspot. I just can't figure out how to hook the tv to it. The only setup network option is "wired". No wireless option. Under wired it wants me to enter ip addresses etc. I would think there should be a way to enter the wireless router name and password. Any suggestions?
whitegs is offline   Reply With Quote
Old 01-11-2016, 03:08 PM   #16
dugster's Avatar
Kennesaw , Georgia
AS models with twin air conditioners have only one fantastic fan and no front generator input connection. Single air models have 2 fans and the front genie connection.
dugster is offline   Reply With Quote
Old 01-11-2016, 03:15 PM   #17
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
If this is the case then the your TV does not have wireless capability. Your Chromecast does which is why it works. To use the TV "apps" that show you will need to have to set up a LAN in your AS and then connect the TV to it via Ethernet cable. Bottom line the Chromecast or something similar (AppleTV) will work with your hotspot.
I like the AppleTV option over Chromecast because you can use Airplay to display content from your iPad or iPhone on your TV without having to have a network connection. See video below for more info:
AStreamNerds is offline   Reply With Quote
Old 01-11-2016, 03:19 PM   #18
The Plains , Ohio
Old 01-11-2016, 03:44 PM   #19
2000 30' Excella
2014 30' Classic
Princeton , Iowa
With your hitch besides all the info you have got, be sure to push the level as far as you can forward then pull up. I had that with my new trailer.
larryglarson is offline   Reply With Quote
Old 01-11-2016, 03:46 PM   #20
paiceman's Avatar
Upper St Clair , Pennsylvania
Equalizer Hitch - before I disconnect I always chock the wheels good and tight, then take off the chains and the power umbilical cord and then the two equalizer bars and then lower back down a bit to unlatch the hitch and raise it up off the ball.
Bud
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-11-2016, 06:32 PM   #21
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The TV isn't a "smart" TV?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-11-2016, 08:09 PM   #22
The Plains , Ohio
i guess I need to read the manual I've never owned a "smart" TV, but what I did was turn on the TV, change to HDMI, turn on the HDMI remote and up came icons for Netflix and other streaming sites. I tried to set up a wireless network connection but all I can find on the HDMI setup is for a wired connection. Maybe I'm just plain dumb, but how would I find out if I have a "smart" tv that has wireless capability?
I'm getting back to the pile of paper that came with the trailer. Everything is so new it's a bit overwhelming.
Old 01-12-2016, 08:19 AM   #23
Manassas , Virginia
If the TV has Netflix and other app type options on the TV itself then it would be considered a smart TV. I do not have one in my 2015 but I can only go by the OP's description.
You Tube Channel "Airstream Nerds":
https://www.youtube.com/c/airstreamnerds
Find Us on Facebook: https://www.facebook.com/airstream.nerds.7
Old 01-12-2016, 08:23 AM   #24
Manassas , Virginia
Quickest way would be to find out the model of the TV and then search on the Internet. I am assuming that they are still using Samsung TV's. If so you can go to the Menu then look for Network setup. If you have wireless built in it would be listed in this menu. Some models show a wireless option in the menu but it is greyed out and you are unable to select it. In that case the TV does not have it.
Old 05-06-2016, 10:47 PM   #25
2016 26' Flying Cloud
Southlake , Texas
I went to Walmart and bought a wireless Blu-Ray player and it works great. Also got an HDMI switch that allows me to switch between Dish Network and Blu-Ray player. Otherwise you are physically changing cables which is almost impossible without pulling the Blu-Ray player out.
Bgibbs is offline   Reply With Quote
Old 05-10-2016, 10:07 AM   #26
dugster's Avatar
Kennesaw , Georgia
We also have a new 28FC. If you have one AC you will find the generator connection up front on the driver side. If you have a 2nd AC there is no front generator hook up provided.
First Trip Out, Found a couple issues vvolf27 Our Community 0 09-13-2010 11:20 PM
First Time and Full Time! JRoss3030 Member Introductions 9 03-21-2010 12:28 AM
Sway Issues First Time in 15 Years overlander64 Hitches, Couplers & Balls 21 07-08-2009 01:08 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 09:55 PM
First time owner, doghouse issues gsymes Our Community 6 01-20-2004 06:41 PM
