Old 07-13-2019, 08:14 PM   #1
2018 27' Flying Cloud
Houston , Texas
FC 27 Entry Stairs
Our 2018 FC has lost 2 bolts from the entry stairs on separate occasions, which completely disables the stairs for the remainder of the trip. The first time the bolt was accessible and was replaced by the dealer. The latest (today) appears to require removal of the entire stairs assembly to replace the hinge bolt from the inside.
Is this a common problem for Airstream stairs?
Monty99 is offline   Reply With Quote
Old 07-13-2019, 08:36 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I donít know if this has changed a lot since 2012 but I just replaced my 2012 stairs and the bolts all come up from the underside of the trailer, not inside. If you open the stairs a bit, do you see from the top of the stairs where they connect to the trailer the 4 bolts? They go in from the underside of the top of the stairs and connect to a stationary nut over the top of the lip - at least thatís how it works on my 2013. Good luck!
Old 07-15-2019, 10:29 PM   #3
Houston , Texas
SteveSueMac - thanks for this. I'm not sure if mine is the same arrangement as your 2012, but it's easier to describe with photos.
First one is the left side of the stairs (complete) and the second shows the right side with missing bolt. The bolt apparently vibrated loose and fell out while we drove.
The last two are shots of underside with the stairs retracted. It's not that clear how to pull the unit out but I will try tomorrow.
ID:	346749   Click image for larger version
ID:	346751   Click image for larger version
Old 07-16-2019, 05:27 AM   #4
W , New England
Got it. Yours are a different type than mine - not sure how those work. Sorry about that!
Hopefully someone with a set like yours can help or you could always check your dealer, someone in your local WBCCI unit, the AS factory or probably even YouTube....good luck!
Old 07-16-2019, 09:43 AM   #5
Chelsea , Maine
When you put it back together blue Loctite is your best friend.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 07-16-2019, 03:47 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I drilled out the rivets on the banana wrap to gain access to the back side of the 'slide' bolt. (POI...at the time the shoulder bolt was not available, I had to MacGyver my own, hence the hex head)🤓
While your at it check for ware on the channel lock ridge, I used a round file to clean up the radius.
ID:	346837   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 07-16-2019, 07:20 PM   #7
Houston , Texas
Many thanks for the great comments. The prospect of drilling out rivets for access to the bolts makes me hesitate a little bit. I'm in LasVegas right now as luck would have it, so I will give the dealer a call in the morning. It doesn't seem like this should have happened twice already on a 2018 trailer - maybe they forgot the Loctite!
Height of Stairs and from Ground to Threshold? MaryGladys 2009-2015 Flying Cloud 1 05-04-2016 04:39 AM
Stairs extend and won't retract israndy Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 02-22-2016 11:04 AM
adding stairs to 1978 Argosy 6.7 paddle whisp All Argosy Trailers 5 07-19-2015 02:43 PM
horn, heater, mirrors and stairs not working Scott bono Electrical - Systems, Generators, Batteries & Solar 4 02-19-2013 10:09 PM
Spiral Stairs RLS The Pet Forum 9 01-21-2011 12:41 PM
