Originally Posted by whitegs
Just ike the referenced thread, the converter and fuses are under the frig. I can hear the water pump under the hall closet but I just can't get to it.
I think then your best bet is to go the route you were reticent to earlier in the thread. Once you complete your previous winterizing steps, finish by dropping a gallon or two of RV-grade antifreeze into your fresh tank, turn on the pump, and fill your lines to your faucets, etc., through the pump.
This will clear the fresh water sufficiently from the pump and offer winter storage protections without having to locate and/or remove the pump at the present time.
From my own experience, I usually de-winterize/re-winterize 8-10 times per winter to go camping; and the RV anti-freeze clears from the system fairly quickly. I think I've only ever noticed a lingering smell of it in the shower; but I also have an water-saving shower head, so it's likely simply a matter of how long it takes to pump the same amount of water through the line.
Ian
