Old 10-17-2016, 07:39 PM   #1
2017 27' Flying Cloud
Monroe , Washington
Climate control thermostat in Flying Cloud 27'
Just got the trailer to me it seems that the thermostat is not working well hot in back end and. Colder in front and the heater runs forever and is very noisy. Anybody have similar problems?
Peny is offline   Reply With Quote
Old 10-17-2016, 08:44 PM   #2
2017 25' Flying Cloud
Gold Country , California
Hi and welcome!
There are 2 heating options in your trailer. The heat pump, "HP" on the thermostat mode, is almost as noisy as the ac. This is a function of the ac unit that uses electricity to heat the air. The furnace, "fur" on the thermostat, is not as loud. You may have to adjust your vents to achieve a uniform temperature while using the heat pump. I don't know if you can adjust the vents for the furnace ( those are the vents that are low in your trailer).
Matt
NorCal Matt is offline   Reply With Quote
Old 10-18-2016, 05:01 AM   #3
2014 27' Flying Cloud
Wenatchee , Washington
Our furnace warms up the trailer pretty quickly on our '14 FC 27FB.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 10-18-2016, 05:37 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Do you have one air conditioner or two?
Old 10-18-2016, 11:52 AM   #5
2016 25' Flying Cloud
Friday Harbor , Washington
My FC 25 has a furnace (fur) that comes on instantly with cool breeze at first (3ish minutes) then warms the whole trailer in about 20 (even less) minutes when the outside temp is 45-50ish and inside might be 50ish. It seems your heating experience is requiring too long, but I have no idea why. Hope my newbie experience is helpful to you.
Rob Cope is offline   Reply With Quote
Old 10-18-2016, 01:24 PM   #6
2014 27' FB International
sugar land , Texas
The temperature sensor for the zone 2 (front) is sensing a temperature that is higher than the ambient room temperature. On the 27 the sensor is located behind the TV on the wall next to the frig and that wall is wormer than ambient room temperature. On my 27' I set my thermostat to turn of the AC about 84 to 86 degrees when zone 1 (bedroom) is set about 10 degrees cooler. So if you set zone 2 to start the heater at say 76 it won't come on because the sensor is reporting a temperature that is already more than 76 degrees. Hope this helps. Yes this confused me until I read a post here that explained about the sensor.
us3rnam3 is offline   Reply With Quote
Old 10-18-2016, 10:53 PM   #7
Monroe , Washington
Heater
I only have one HP and only zone 1 works on the climate control, anybody know where the sensor is locate in this setup?
Old 10-23-2016, 05:10 PM   #8
I miss NOT knowing things
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Check the ducting for crimps or longer than necessary
While installing an accumulator (for the plumbing) in our 2015 23' FB Flying Cloud I discovered heat ducts that had been smashed partially closed or longer than necessary which reduced the efficiency of moving heated air around the trailer.
Setting the thermostat is a challenge as the delta (temperature swing from on to off) is as much as 6 or 7 degrees and the location of the thermostat isn't ideal. Not much you can do with those two issues without investing more $$.
Try cracking a window or vent remote from the thermostat or remote from the area that you spend the most amount of time. It is important to allow hot air to push the cold air out of the trailer and remember hot air rises. A small battery powered fan might improve the heat distribution.
Robere & Jacqueline
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew
Robere is offline   Reply With Quote
Climate control modual for 1986 34.5 bbabich Classic Motorhomes 1 04-18-2016 03:03 PM
I'm new! Questions about climate control systems - 1979 31' Sovereign Gasgano1979 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-24-2013 05:35 AM
Climate Control Fuses vegburner Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-15-2011 09:42 AM
Desert Climate Meehan Full-Timing 9 05-25-2009 03:05 AM
Are there warm climate Airstream Parks on the East coast who sell lots chazols Our Community 11 08-17-2004 06:04 PM
