Old 01-18-2017, 07:44 PM   #15
2017 30' Flying Cloud
Bedford , New Hampshire
New Info
Hi, all...
Since my original post, I've learned a couple of things. First, the current thinking does seem to be that Airstream is leaving little tabs when cutting the holes for the vents. I have now heard this from a couple of people, and then the mechanic at our dealer said that he'd fixed the problem on other units by removing the tabs that were left by Airstream and then bending some of the plastic tabs on the vent itself out a little further so they "grab" the ceiling better. He's got our Airstream for the winter (sniff) and is going to work on fixing the problem. We'll find out how it worked in the Spring.
While I was gathering this information, we were on a three-month trip with our kids and these vents kept falling unpredictably, sometimes on one of us! One of the vents is positioned directly above the bedroom television, and we were also worried about that being broken, so we had to come up with a temporary fix. My husband came up with something that worked beautifully. I'll describe here, and try to attach photos in case someone else wants to try it.
He ran three zip ties through the plastic tabs on the vents, so they created three loops, spaced around the outside of the tabs. He then bent these upwards and held them in place while reinstalling the vent in the ceiling. The zip tie loops sprung back down above the ceiling skin, holding the vent in place, acting something like a wall anchor. They never fell again for the remainder of our trip. Hope this helps!
ID:	278388   Click image for larger version
MeeshM is offline   Reply With Quote
Old 01-24-2017, 05:54 PM   #16
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
I had several fall in early trips. When I took my AS to dealer for warranty work one of the issues was this. They rebent tabs according to mgr and I haven't had any issues since.
From dblee50 and Southern Belle on the road
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 01-24-2017, 07:53 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We specifically went with a 2015 23D International Serenity without the overhead air duct and flow vents.These rotating vents have been a chronic problem for lots of folks and the factory has been clueless......
switz is online now   Reply With Quote
Old 02-27-2017, 12:33 PM   #18
MarkFinATX's Avatar
2016 28' Pendleton
Santa Fe , New Mexico
I was having the same problem in our Pendleton. The directional vents are a great idea, but poorly executed.
I put together a punch list of about a dozen items and hauled her up to JC last fall. Our service tech, Lee, did a fantastic job with every issue. For the vents, I believe he used double sided tape, maybe an Automotive Grade? Not a one has fallen off since.
Don't look back, you're not headed there anyway
MarkFinATX is offline   Reply With Quote
Old 05-27-2017, 05:06 PM   #19
QC TORPEDO's Avatar
Queen Creek , Arizona
Smile Vents A/C registers
I may be on to a permanent solution. Watch Ceiling A/C registers
for updates. I just received some parts that will be used to end this frustration in two ways; One: no more falling vents. Two: the vents will be directed downward, not out against the ceiling by the angle of the louvers.
More next week.
QC TORPEDO is offline   Reply With Quote
Old 05-30-2017, 03:40 PM   #20
QC TORPEDO's Avatar
Ta da!
Go to Ceiling A/C Registers to see a possible solution to limited air flow and falling vents.
Old 06-05-2017, 04:48 PM   #21
Navarre , Florida
Originally Posted by MeeshM View Post
Hi, all...
Hi Meesh...wondering if your "zip tie" fix continues to be working...I have a brand new 27 FC and both the vents fell out hitting a guest in the face. I am far from my dealer, drink milk with two hands, so need a simple fix that is will correct the problem.
I find it hard to believe that AS continues with this faulty design...not expected on a 90k coach. One lawsuit by someone who gets hurt and I expect it would be instantly corrected.
Any advice on your fix would be greatly appreciated.
Thank you!
schristo is offline   Reply With Quote
Old 06-06-2017, 07:32 AM   #22
QC TORPEDO's Avatar
Your solution
Go to http://www.airforums.com/forums/f542...rs-166383.html
See if this solution works for you. I have posted pictures of the result. No more falling vents, better air flow.
Old 06-06-2017, 10:27 AM   #23
BirdDog's Avatar
2015 25' FB Flying Cloud
Carriere , Mississippi
My Solution
My problem was there is a metal tab in the hole in the ceiling and no corresponding slot on the register. Rather than remove the tab (difficult and messy) I made a slot in the register. This was originally posted here.
My vent register problem seems different than Brians'. I have the 2015 25'FB and my vent hole had a tab that prevented the register from seating properly. Could this be Airstreams solution to Brian's inquiry? Anyway, I had to modify all my registers to get them to snap in place. Made some measurements and took some pics.
Hole diameter 5.00"
Hole diameter including tab 4.84"
Register plastic ring diameter 4.91".
Haven't had a problem with falling vents before the fix today - haven't used it since I bought it last year. Still outfitting the camper.
There was always a large gap on one side of the register and now is more flush with the ceiling.
Joel
BirdDog is offline   Reply With Quote
Old 07-01-2019, 11:13 AM   #24
2017 28' Flying Cloud
Thomasville , Pennsylvania
Member
Ok, so here are some pics of a simple solution for the falling duct vent diffusers. I made these clips out of 1/2" wide .020 thick SS strapping. A little tricky to fabricate, but can be made with simple tools (pliers, snips, hammer). I have included detail pictures of the finished product.
Once made, they are simple to install. Once installed they allowed the diffuser to function normally and diffuser will not fall back out.
I had some trouble loading a better detailed video here. It wont allow, but I think you will clearly get the idea of how to make them and how they can work from the pics.
Name:	photoAirstream diffuser3.jpg
ID:	345043   Click image for larger version
Name:	photoAirstream diffuser2.jpg
Name:	photoAirstream diffuser1.jpg
ID:	345045   Click image for larger version
Name:	photoAirstream diffuser4.jpg
Muddycreek is offline   Reply With Quote
Old 07-01-2019, 12:51 PM   #25
Oh, also, I did not show it in the drawing but I used two clips on each vent 180 degrees opposite each other. And I did not bend the holding tab down until after the diffuser was pushed back into place. I pushed the diffuser back in place with my new clips centered on the widest space openings on the back of the diffuser. This allows the diffuser to spin freely, without any interference, as it was designed to do.
Old 07-01-2019, 01:48 PM   #26
Member
Here is clip dimension info, for the size I fabricated and used, which worked very well.
Name:	photoAirstreamVent dimension2.jpg
ID:	345073   Click image for larger version
Name:	photoAirstreamVent dimension 3.jpg
Name:	photoAirstreamVent dimension4.jpg
ID:	345075   Click image for larger version
Name:	photoAirstream Vent dimensions1.jpg
Old 07-01-2019, 05:00 PM   #27
twbucksr's Avatar
2015 22' FB Sport
2018 27' Flying Cloud
Fredericksburg , Texas
The factory fixed ours by screwing them into place. They are still adjustable. You might contact them or your dealer for their fix.
twbucksr is offline   Reply With Quote
Old 07-01-2019, 05:09 PM   #28
Mollysdad's Avatar
Great idea!
I might use it if mine fall again.
When I look at the stock vent, there are black plastic clips built in. Evidently, they don't hold well.
When one of mine falls, I align two of the plastic tabs with the side of the hole that has a bit of a burr, then push up firmly until I hear a "click".
ceiling falling down 07007 General Interior Topics 6 07-04-2015 04:55 AM
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
Ceiling Covering Falling Down RonH General Interior Topics 2 03-08-2011 02:37 PM
Falling padded ceiling panel 94 campster Interior Restoration Forum 5 03-31-2010 07:58 AM
falling ceiling , 96 Excella mauser1 General Interior Topics 5 05-04-2007 10:31 AM
