09-10-2019, 12:21 PM
2019 25' Flying Cloud
Bozeman
, Montana
Can I use 1875 watt hair dryer when on 30 amp electric hookup?
Hi all! We have only boondocked for the past 2 years, and will be using electric hookup for the first time. Can I use my hair dryer, or will it blow a fuse? Sorry, very electrical-knowledge challenged! Thanks so much!
09-10-2019, 12:33 PM
2020 25' International
San Diego
I just used my 1600 Watt hair drier with no problem while plugged into 30 amp shore power. Hope that helps.
09-10-2019, 12:44 PM
Bozeman
, Montana
1875 Watt HD
Thanks so much! My hair dryer is 1875 watts. Worried that will trip a breaker. What do you think?
09-10-2019, 01:09 PM
1973 21' Globetrotter
Houston
The good old equation P=I*V should help.
Power+Amperage*Volts
1875watts=I*120V
So I=15.6 Amps.
So, if the only thing you are running is your hair dryer, you are pulling 15.6 amps. Now, you might trip a 15A breaker in your trailer, but you are far from exceeding the 30A capacity being delivered to you. Remember also, that all of your appliances are additive, so if your air conditioner is pulling 20A, your microwave oven is pulling 10A, and then you turn on your hair dryer, you will be trying to get 45.6A through a 30A connection... Expect it all to shut down.
good luck!
09-10-2019, 01:13 PM
2017 30' International
Broomfield
You are fine
09-10-2019, 03:00 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
So what if you trip a breaker. Just flip it back on. You will need to have the hair dryer on a breaker that is not running anything else at the time.
09-10-2019, 03:04 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Also, run it on medium if it starts tripping a breaker.
09-10-2019, 03:33 PM
Sag Harbor
, New York
Bingo!
09-10-2019, 03:39 PM
Sag Harbor
, New York
When you plug it in at home, does it work OK on a standard 15 Amp circuit, or do you have to use a special 20 Amp outlet like those for air conditioners etc.?
09-10-2019, 03:46 PM
2015 28' International
Ofallon
, Missouri
My daughter just took a trip in our AS and with A/C running her hair dryer tripped a breaker. First time for us.
09-10-2019, 03:55 PM
2018 27' Globetrotter
Apollo Beach
One must be careful of how many appliances are running with a 30A Airstream, especially when the A/C is running. We have tripped breakers with the A/C and Microwave running and usually remember to turn the A/C off when microwaving. Both can run together sometimes, but if the converter is also charging the batteries it likely will trip the breaker. I wouldn't run that hairdryer with the A/C and Microwave running. You can usually get away with the A/C and one additional appliance.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
09-10-2019, 04:05 PM
1981 31' Excella II
New Market
, Alabama
Turn off everything else that is big like the AC and microwave and electric water heater if you have one. You might consider getting a compact travel size hair dryer as well. Make sure you know where the breakers are located.
Perry
09-10-2019, 06:03 PM
Hendersonville
, North Carolina
High draw appliances
If the electrical post that is at our sight has an additional standard plug in outlet (15/20 amp) I always plug in a 25 or 50 foot 12 gauge extension cord to it and run it to the awning area of the AS. Any high draw appliance, hair dryer, crock pot, toaster oven, coffee maker etc. gets plug into that extension cord. That frees up the 30 amp circuit to the AS to run the A/C, Micro, H2O Heater, etc. We always set up a nice table and 2 chairs under the awning area. Makes for convenient place for those items on the extension cord. DW does not mind drying hair outside. Your results may not be the same!
09-10-2019, 06:12 PM
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs
Just stay away from the vintage hair dryers...
09-10-2019, 08:37 PM
2017 23' Flying Cloud
Bartlett
, Tennessee
Turn off air conditioner and electric water heater element while using blow drier and you will be fine. My wife blew the breaker a few times before she finally learned this. We have never had a problem with the refrigerator on electric, but it is possible.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
09-10-2019, 08:43 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Watts/volts=amps
1875/120=15.6
09-11-2019, 07:16 AM
Bozeman
, Montana
Thank you, everyone, for your help. I will turn the hair dryer on the lowest setting. I haven’t looked for the breaker box yet, but I’m sure I’ll find it. Safe travels out there!
09-11-2019, 09:13 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
buy a lower wattage one for the trailer ....we got one about 8-900w? ....wife likes it and its easy to use on inverter while boon docking
09-11-2019, 09:14 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
09-11-2019, 09:25 AM
1966 17' Caravel
PINE PLAINS
, New York
If you are staying in a campground, the common shower area is always a safe bet...or get your hair styled, like I have done, so that you can let it dry naturally...
