Old 09-10-2019, 08:37 PM   #15
2017 23' Flying Cloud
Bartlett , Tennessee
Turn off air conditioner and electric water heater element while using blow drier and you will be fine. My wife blew the breaker a few times before she finally learned this. We have never had a problem with the refrigerator on electric, but it is possible.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 09-10-2019, 08:43 PM   #16
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Watts/volts=amps
1875/120=15.6
Dept of ďOverKillĒ
Old 09-11-2019, 07:16 AM   #17
2019 25' Flying Cloud
Bozeman , Montana
Thank you, everyone, for your help. I will turn the hair dryer on the lowest setting. I havenít looked for the breaker box yet, but Iím sure Iíll find it. Safe travels out there!
Hlifson is offline   Reply With Quote
Old 09-11-2019, 09:13 AM   #18
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
buy a lower wattage one for the trailer ....we got one about 8-900w? ....wife likes it and its easy to use on inverter while boon docking
rucos is offline   Reply With Quote
Old 09-11-2019, 09:14 AM   #19
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
No hair don't care
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 09-11-2019, 09:25 AM   #20
1966 17' Caravel
PINE PLAINS , New York
If you are staying in a campground, the common shower area is always a safe bet...or get your hair styled, like I have done, so that you can let it dry naturally...
lakemaiden is offline   Reply With Quote
Old 09-11-2019, 10:32 AM   #21
2019 25' International
Washington , Washington, D.C.
My standard practice is to turn the air con/heat system OFF while I use the hair dryer and then turn it back on when finished. If you do overload and it flips off, just flip the breaker back on.
PatLee is offline   Reply With Quote
Old 09-11-2019, 10:36 AM   #22
A flashlight is useful when looking inside your breaker box. If you have twin config. the box is at the end of the right twin near floor. Lid flips down. Look for the switch with the number "30" imprinted on it. It will look a little bit out of alignment, just push it down and back up into alignment with others and voila, power restored. I, too, am 'electrically challenged' but I had to learn this in my early days on my last long trip.
Old 09-11-2019, 10:55 AM   #23
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Yep, wife's 1875 hair dryer works fine . Just make sure the microwave and air conditioner are off.
Streamracer is offline   Reply With Quote
Old 09-13-2019, 08:52 PM   #24
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
You will find your answer in this thread if you are boondocking:
http://www.airforums.com/forums/f382...ng-197314.html
With 30 amp shore power, no problem.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 09-13-2019, 08:56 PM   #25
waninae39's Avatar
2017 22' Sport
NCR , Ontario
that uses 2/3 of the 30a service
your ok as long as the load of everything else is under 9A. ie no uwave or AC running
waninae39 is offline   Reply With Quote
Hair blow dryer and A/C or A/C and microwave dlenloe 2016 - Current Flying Cloud 12 06-01-2019 11:57 AM
Add a Washer/Dryer to '76 with 30 Amp Service tbashin General Repair Forum 7 04-14-2018 06:51 PM
RV Hair Dryer Anoyes Our Community 8 03-01-2018 05:48 AM
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 07:59 AM
12V Hair Dryer Batch General Appliance Topics 4 02-15-2008 09:57 PM
