09-21-2017, 11:52 AM
Morrisville
, North Carolina
Bunk Beds In 25RB Twin FC?
I am wondering if anyone out there has taken a newer model 25 foot FC with Twin beds in the rear and considered or done bunks over the twins such that you could sleep four people in the rear of the unit? I see a lot of bunks and bunkhouses, but mainly renovations of much older units.
09-21-2017, 01:31 PM
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs
You would have to remove the overhead storage on the right side, and the half-wardrobe closet on the left side, including the TV...
09-21-2017, 01:41 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The problem is that you really get in trouble with the windows. The "bunks" pretty much have to be at window level. There isn't enough room to keep them above the windows. Not really 100% correct, but close. Once you get bunk structure and a mattress in there, the poor person in the bunk will be flush up against the ceiling. I certainly would not want to sleep that way.
You have to support the bunks somehow. That either involves bolting into the existing structure or making something from scratch. Even if you are above the windows, the cutouts for the windows eliminate a bunch of structure to tie into. That gets you back to some sort of added supports. The curving walls are your enemy in terms of doing it "simple". There's bound to be impact on the sleeping space in the lower bed.
Could you do it? Sure on a big enough bet, anything like this could be done. Unless you are a family who are all under 5' tall, not sure you would want to.
09-21-2017, 03:13 PM
1973 Argosy 24
hartselle
, Alabama
I don't know if the window placement is that much different from the placement in my Argosy, but my factory bunks leave plenty of space for the top and bottom bunks. Attachment 1
09-21-2017, 03:15 PM
1973 Argosy 24
hartselle
, Alabama
09-22-2017, 07:55 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The arrangement I was thinking of is more like what you see in the FC 30 bunk version. The bunks are fixed in place so there is no fix up required. Looking at the twins in the back of this trailer, if you pulled all the cabinets out, some sort of flip down might work. It would be sitting a bit above half way on the windows when "down" in order to give the lower bed user room to get in and out of bed.
09-22-2017, 10:26 AM
Morrisville
, North Carolina
That was my thought, if the cabinetry was removed and the bunks were set about half way up the window, had anyone considered that or implemented something like that? Seems like maybe not really. Maybe most people do not want to immediately make that kind of modification to their brand new AS ;-)
09-22-2017, 06:38 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Im not sure it would work, but you might build something like the Pullman fold down bed in a train. That way they would be up and out of the way during the day, if that is a consideration.
guskmg
09-23-2017, 06:55 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you block the windows half way up - how do you operate the shades? They are tough enough when you can get at the whole system. Do you just permanently black out the windows?
One other thing to look into is weight. Pulling all the cabinets gives you something to work with. If you do a net weight add that far back, it's not a good thing.
12-14-2017, 12:49 AM
Arcata
Did you ever figure out the bunk situation? I'm about to add a third bed to a 30 twin and am searching for ideas. I was thinking of adding a third bed right on top of the middle "end" table, east to west. My 4 year olds would be sleeping on the original twins, but with their heads by the door. The third bed would be hover over the the tops, now the ends, of the original twins, so the 4 year olds could tuck their feet under, if need be (although they are rather short, their feet prob wouldn't reach anyways). The third bed would be right at the window, but when it was chilly I would be able to insulate it, and maybe permentely take down the curtain and fashion something a little more cozy.
I would most likely need to take down the end cabinets- their little heads could potentially bang on them when they got out of bed.
But I'm also tossing around the idea of adding a fold down bed above on the of the twins. Hmmmm...
12-14-2017, 06:46 AM
Byron Center
, Michigan
I took these photos in a 60's Airstream at the local dealer to show how the bunks in this model were done. It's a mid-twin layout, so the back corners of the roof don't come into play like they would in a rear bunk model. The bunks cover the window, and appear to fold up in the middle for tighter storage. The cables are anchored to the ceiling, and appear to have been moved at some point to provide a little more shoulder clearance walking through.
