Old 04-04-2018, 11:24 AM   #1
2017 25' Flying Cloud
Queen Creek , Arizona
Bumper Storage Latch
The thingys that hold the cover closed on the rear bumper storage on my 2017 FC 25FB are impossible to use. It is the same device used to hold the door to the water heater closed.
Has anyone found an alternative? What can I replace them with? Picture below.
QC TORPEDO is offline   Reply With Quote
Old 04-04-2018, 11:27 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Why are they impossible? I'm always impressed that they easily line up to close- it seems like it should be difficult but I don't find it so.
2012 Dodge Durango Hemi/AWD
Old 04-04-2018, 12:43 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I always thought that those little spring clips were pretty easy to deal with. I can't imagine anything else that would actually work would be any easier to use. That is the same clip that is on the exterior water heater access panel. These little clips have the added benefit of being able to put a small pad lock on them for further security.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 04-04-2018, 12:52 PM   #4
Merkel , Texas
What seems to be your difficulty in using these clips? I find them rather simple and effective. No disrespect intended. Just curious.
afneill is offline   Reply With Quote
Old 04-04-2018, 01:01 PM   #5
4riveteers's Avatar
2016 27' Flying Cloud
SF Greater Bay Area , California
Although I find these clip latches easy to use as others do, I agree with QC in that the question should be asked is there an alternative? I do put a small padlock on both of mine. Unfortunately it could be pried off with a common screwdriver.
I store my $200.00 plus 50 amp Grey power cable in there and I would like to make it a bit more difficult for it to “walk away”.
I was thinking of trying a “hood pin latch” like the ones drag race cars use to keep their hood from flying off half way down the track. I believe “Summit Racing” sells them on line. Would require some modification to the hole size?... just my .02
John
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 04-04-2018, 01:04 PM   #6
Silverpuller's Avatar
2018 26' Flying Cloud
Thornton , Colorado
Wish we still had the little spring clips! I never personally had any difficulty operating them, plus being able to use a small padlock was a nice low security feature.
Our 2018 uses a non-lock version of the same type of latch as the exterior compartments. Ok, but can’t be locked.
Silverpuller is offline   Reply With Quote
Old 04-04-2018, 02:32 PM   #7
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
There are lots of lock alternatives from a common hardware hasp to more aesthetically pleasing automotive hood pin type locks. Look at the marine hardware catalogs for an upgrade that looks better than galv.
Like the OEM solution. Use the space for items that are not very expensive, but needed. Have been concerned they would fail over time, but they seem to be doing reasonably well.
Please post your final solution. Will be interesting to consider. Pat
Old 04-04-2018, 03:11 PM   #8
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Like many others, I really need a further explanation of why/what about them is "impossible to use?" Are yours damaged, bent or ???
The Ice Man is offline   Reply With Quote
Old 10-13-2018, 12:13 PM   #9
Finally
Well, after getting beaten up over the "impossible to use" statement, I decided to finish this story.
I put weather-stripping around the compartment and made it rain-resistant. That is what made the little clippies so hard to use. I removed the clips and installed jam-nuts in the holes. The slots for the clippie were drilled out to accommodate a threaded knob which was drilled to accept a cotter key to keep it in place.
Now when the compartment is closed the knobs are screwed down and the stuff inside stays drier.
Old 10-21-2018, 01:32 PM   #10
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
I thought that back compartment was not intended to be water proof (which is why it has drains and the steel flooring) so I never worried about it. I store my drain hose there.
DewTheDew is offline   Reply With Quote
Old 10-21-2018, 01:56 PM   #11
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Couple comments on this; I also stored my power cable and my Rhino drain hose in there with my first 3 25' AS's, and never thought about it, but it was messy. The Rhino would not fit into the drain hose compartment due to the size of the fittings. It did get messy, but I also thought about putting locks on those if I really wanted to worry about someone stealing something in there...but who would bother? It gets pretty messy...
With my 28' Twin, I have 3 large storage areas, and now I keep my water hoses and gray 50amp cable in the side compartment, along with my tv coax cables, couple more leveling blocks, and tire covers. Also keep some other stuff in there. I found out the Rhino drain hose had bigger nubs on the connection ends which is why they would not fit; the dealer when I picked up my new rig, supplied a different sewer hose with smaller nubs which fit into that hose holder on the AS..daaaah, never thought the connections on a sewer hose could be different on different brands before…
Anyway, only thing's I keep in the rear bumper now is the 90 clear connector to the sewer hose, a 15' water hose for the tank cleaner, and some lego leveling blocks. It does get dirty back there, so I wash it out when washing the rig...not a big deal to spray down. I also noticed the new models do not have the same locking mechanism mentioned at start of this post. New clips are plastic and stick up a bit..first thoughts to me were they seem like they could be knocked off or broke off- sticking up like they do...putting stuff away in the rear locker above the bumper or loading my bikes? Actually like the existing folding spring loaded clips.
My recommendation: get a twin bed model with more outside storage for your power cords, etc; get a sewer drain hose that will fit in the intended storage holder, and don't put anything of value in your bumper! (no offense intended by recommending the twin model!)
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 10-29-2018, 07:30 PM   #12
Lake Charles , Louisiana
Had problem twice with driver side latch falling off. After the second time, I noticed the latch was offset slightly from the lid hole. Solved problem by notching lid so latch was inline with hole.
dsoulier is offline   Reply With Quote
Old 10-30-2018, 03:40 PM   #13
gypsydad's Avatar
Great thinking...some folks might take it to the dealer to fix...wait for 5 weeks till it was done, or perhaps just buy a new cover! LoL
Old 10-30-2018, 05:35 PM   #14
2015 30' Classic
Saint Augustine , Florida
I don't put anything of value in that compartment; just a kneeling pad ( I'm old)_ and sewer hoses. Someone wants to steel them; knock yourself out. Anything of value goes elsewhere where it can be locked. Further, locks or not, if someone wants to steel something, a lock isn't going to stop them.
My .01
accordionman is offline   Reply With Quote
locking latch for the bumper door Reeltimer 2016 - Current International 1 02-25-2018 05:42 PM
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 10:12 AM
"PVC" Styled Sewer Storage/Rear Bumper Storage Repair Frank&Mike Bumpers & Bumper Storage 5 11-04-2010 09:30 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
Rear bumper storage latch mystery Shelby Copeland Bumpers & Bumper Storage 3 12-02-2003 11:49 PM
