Old 10-17-2018, 03:47 PM   #1
2018 30' Flying Cloud
Charlotte , NC
Battery Disconnect - when do I use it?
We just took delivery of our new Flying Cloud FB30 Bunk (The Steely Dan!). Already went out for a weekend and love it. No major issues. My question is when do I use the battery Disconnect switch. I do have twin solar panels factory installed. I assume I would disconnect when in long-term storage (though solar panels may keep batteries charged anyway). What about when I am not suing the camper for 2-4 weeks? Disconnect or let the solars recharge the parasitic drain? Any other times that I should use the disconnect?
SteelyRick is offline   Reply With Quote
Old 10-17-2018, 03:59 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Always turn the battery disconnect switch off when you are storing your trailer. Short or long term.
wulfraat is offline   Reply With Quote
Old 10-17-2018, 04:34 PM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
You will always have parasitic drain as long as the batteries are hooked (wired) up. If you don’t use the disconnect switch, you will have a greater amount of parasitic load.
I always use the disconnect switch any time I don’t need power. Because I am storing the trailer under cover, and I don’t get sun on the solar panel, for no use longer than a few days, I disconnect the ground wires to the batteries.
Old 10-17-2018, 04:35 PM   #4
Long Island , New York
What does your owner's manual have to say?
OTRA15 is online now   Reply With Quote
Old 10-18-2018, 11:24 AM   #5
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Answers above are fine for the conditions they describe.
I store my trailer with a shore power hookup and run AC to prevent mold which grows in our high humidity. So, the only time I hit the "store" switch is if I'm working on the 12 volt system and want it deenergized. I'm probably in the minority (ok... lunatic fringe) with that approach, but it works for me.
GammaDog is offline   Reply With Quote
Old 10-18-2018, 02:56 PM   #6
2016 25' Flying Cloud
Friday Harbor , Washington
More on Battery disconnect?
Seems to me???? Anytime I have shore power, disconnect? Mine is a FC 25.
Rob Cope is offline   Reply With Quote
Old 10-18-2018, 11:00 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
I installed a switch that actually disconnects the battery. Our batteries are in separate compartments in the Classic and it's much easier this way for Winter Storage.
“After all these years the reason I continue to love Thanksgiving.....I still sit at the kids table.”
RLC
“We were young and knew nothing...now we are old and everyone else knows everything.”
RLC
"Tahawus"
Old 10-19-2018, 09:20 AM   #8
2017 23' Flying Cloud
Bartlett , Tennessee
I only use the battery disconnect when dropping the trailer off at the dealer for service. However, I replaced the POS battery killing Parallax converter for a Progressive Dynamics PD4655V before I even took the trailer out camping the first time, and I have a 50/30/20 pedestal at home where I store the trailer, so I can leave it plugged in all the time. I let the Progressive Dynamics converter take care of the batteries for me.
(However, I am in the process of installing a 200 amp latching relay to disconnect the inverter from the battery. THAT one I will keep disconnected at all times except when we are boondocking and want the TV/DVD player to work.)
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 10-19-2018, 10:40 AM   #9
I have shore power at home also...the AS is never plugged in unless the batt's need charging.
Even with a 'smart' 4 stage converter I see no need unless its needed. 🤓
I can ck status from the living room.
RLC
RLC
"Tahawus"
Old 10-19-2018, 01:45 PM   #10
OT
Do they make one of those hand-held monitors for homo sapiens' percentage of capacity?
Shades of Peter Sellers' character Chauncey Gardiner in Being There, as he wandered about in his unfamiliar downtown area, trying to get his TV remote control to change what he was seeing!
Old 10-21-2018, 09:59 AM   #11
2007 27' International CCD FB
San Diego , California
If you store the trailer outside, as you have solar, there's no need to disconnect. The solar will tender the Batts nicely.
I do the same. I never even put the trailer in store. It's always on and ready to go.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
pteck is online now   Reply With Quote
Old 10-21-2018, 10:59 AM   #12
2007 22' International CCD
Ditto. I just have to check water level in my batteries, dry desert air tends to evaporate some water from my GC-2 batteries.
rmkrum is online now   Reply With Quote
Old 10-21-2018, 12:59 PM   #13
2017 27' Flying Cloud
Frederick , Maryland
Do you mean a hard disconnect switch or the little one in the trailer by the front door? The battery will still be charged by the solar panels even if you switch off the one by the front door (which I also keep off when I'm on shore power, but switch on when I'm doing something in the trailer while it is stored or before we get to the campground).
DewTheDew is offline   Reply With Quote
Old 10-21-2018, 01:20 PM   #14
Yup, I do the same. Always a good practice to check water levels, at least annually. It's basic maintenance and very easy after learning to how do it once.
Funny, because most look at this as a con. It's actually a great feature that they can be watered.
Batts such as AGM and Gel are advertised as "sealed", yet they are also technically known as valve-regulated lead-acid (VRLA) batteries. They can and will dry out with long term hard use. Yet they cannot be prolonged by watering.
For all those so worried about their converter chargers. People have been using them successfully for DECADES, with healthy long lasting batts. Just simple watering will do your battery good.
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 11:24 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 11:52 AM
Car Battery Low Disconnect in '68 crair Batteries, Univolts, Converters & Inverters 3 06-13-2006 06:29 PM
Battery Disconnect Light FiveGreers Electrical - Systems, Generators, Batteries & Solar 2 04-03-2006 09:01 AM
