10-17-2018, 02:47 PM
2018 30' Flying Cloud
Charlotte
, NC
Battery Disconnect - when do I use it?
We just took delivery of our new Flying Cloud FB30 Bunk (The Steely Dan!). Already went out for a weekend and love it. No major issues. My question is when do I use the battery Disconnect switch. I do have twin solar panels factory installed. I assume I would disconnect when in long-term storage (though solar panels may keep batteries charged anyway). What about when I am not suing the camper for 2-4 weeks? Disconnect or let the solars recharge the parasitic drain? Any other times that I should use the disconnect?
10-17-2018, 02:59 PM
2017 30' International
Broomfield
Always turn the battery disconnect switch off when you are storing your trailer. Short or long term.
10-17-2018, 03:34 PM
Free Range Human
2012 25' FB Flying Cloud
Haines
, Oregon
You will always have parasitic drain as long as the batteries are hooked (wired) up. If you don’t use the disconnect switch, you will have a greater amount of parasitic load.
I always use the disconnect switch any time I don’t need power. Because I am storing the trailer under cover, and I don’t get sun on the solar panel, for no use longer than a few days, I disconnect the ground wires to the batteries.
10-17-2018, 03:35 PM
Sag Harbor
, New York
What does your owner's manual have to say?
10-18-2018, 10:24 AM
2014 25' FB Eddie Bauer
Vero Beach
Answers above are fine for the conditions they describe.
I store my trailer with a shore power hookup and run AC to prevent mold which grows in our high humidity. So, the only time I hit the "store" switch is if I'm working on the 12 volt system and want it deenergized. I'm probably in the minority (ok... lunatic fringe) with that approach, but it works for me.
10-18-2018, 01:56 PM
2016 25' Flying Cloud
Friday Harbor
More on Battery disconnect?
Seems to me???? Anytime I have shore power, disconnect? Mine is a FC 25.
10-18-2018, 10:00 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 👍
I installed a switch that actually disconnects the battery. Our batteries are in separate compartments in the Classic and it's much easier this way for Winter Storage.
10-19-2018, 08:20 AM
2017 23' Flying Cloud
Bartlett
, Tennessee
I only use the battery disconnect when dropping the trailer off at the dealer for service. However, I replaced the POS battery killing Parallax converter for a Progressive Dynamics PD4655V before I even took the trailer out camping the first time, and I have a 50/30/20 pedestal at home where I store the trailer, so I can leave it plugged in all the time. I let the Progressive Dynamics converter take care of the batteries for me.
(However, I am in the process of installing a 200 amp latching relay to disconnect the inverter from the battery. THAT one I will keep disconnected at all times except when we are boondocking and want the TV/DVD player to work.)
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
10-19-2018, 09:40 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I have shore power at home also...the AS is never plugged in unless the batt's need charging.
Even with a 'smart' 4 stage converter I see no need unless its needed. 🤓
I can ck status from the living room.
10-19-2018, 12:45 PM
Sag Harbor
, New York
OT
Do they make one of those hand-held monitors for homo sapiens' percentage of capacity?
Shades of Peter Sellers' character Chauncey Gardiner in Being There, as he wandered about in his unfamiliar downtown area, trying to get his TV remote control to change what he was seeing!
10-21-2018, 08:59 AM
2007 27' International CCD FB
San Diego
If you store the trailer outside, as you have solar, there's no need to disconnect. The solar will tender the Batts nicely.
I do the same. I never even put the trailer in store. It's always on and ready to go.
10-21-2018, 09:59 AM
2007 22' International CCD
Corona
Ditto. I just have to check water level in my batteries, dry desert air tends to evaporate some water from my GC-2 batteries.
10-21-2018, 11:59 AM
2020 30' Classic
Frederick
, Maryland
Do you mean a hard disconnect switch or the little one in the trailer by the front door? The battery will still be charged by the solar panels even if you switch off the one by the front door (which I also keep off when I'm on shore power, but switch on when I'm doing something in the trailer while it is stored or before we get to the campground).
10-21-2018, 12:20 PM
San Diego
Yup, I do the same. Always a good practice to check water levels, at least annually. It's basic maintenance and very easy after learning to how do it once.
Funny, because most look at this as a con. It's actually a great feature that they can be watered.
Batts such as AGM and Gel are advertised as "sealed", yet they are also technically known as valve-regulated lead-acid (VRLA) batteries. They can and will dry out with long term hard use. Yet they cannot be prolonged by watering.
For all those so worried about their converter chargers. People have been using them successfully for DECADES, with healthy long lasting batts. Just simple watering will do your battery good.
10-21-2018, 02:27 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Keep in mind that there is a use/store switch on most stock trailers and on a very few a battery disconnect switch. If yours happens to have both from the factory, much of the advice applies to the use/store switch rather than the disconnect.
10-21-2018, 03:47 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I have had my trailer 12 years now. I have never "used" the use/store switch. I have turned it on and off to see what it does. But I have no "use" for it. I am able to keep my trailer by my house. So I left it plugged into a timer to keep the batteries charged when we had the old univolt. Now with the new converter I just leave it plugged in when we are at home and use the timer when we are gone for several months. I have a second trailer that I leave on a site all year. I disconnect the batteries since they still run down in store.
10-22-2018, 04:14 PM
2017 19' International
2018 25' Flying Cloud
Monrovia
Since you have a 2018 a lot of what others do does not apply to you and the equipment you have. With solar you probably have a very nice battery tender that schedules the charge cycles according to the battery type and charge. Since you are not connected to shore power I would leave it on, unless there is a need to turn it off, such as servicing. When connected to shore power I would turn it off, but then again you have a 2018 with a better converter and better battery tender.
10-22-2018, 04:41 PM
2012 Avenue Coach
Corpus Christi
Drathaar & DewTheDew have the best answers. Your solar will charge regardless of the switch position, so turn it off if not plugged in. That will reduce parasitic drain to a minimum.
10-28-2018, 11:36 AM
2010 25' FB Flying Cloud
Snoqualmie
Similar to Bill M. Have had my 25’ trailer with AGM batteries and solar panels for over 5 years and have never used the disconnect switch. Keep trailer hooked up to 110 at home when not in use (with little ceramic heater). Also never winterize except putting antifreeze in toilet, shower and sinks. Never a problem so far and trailer always ready for use
10-28-2018, 12:41 PM
Anna Maria
No you aren't a lunatic. I have been keeping all previous and current Airstreams plugged in since 2012, 24/7/365. I have shore power at home and the only time it is not plugged in while the occasional boondocking, or when at the dealer being serviced. Not only is it plugged in the Use/Store switch is on as well.
Stock converters and batteries no problems whatsoever. I have yet to replace batteries or converters and I have no solar either. All I do is make sure the batteries have water.
