Old 10-13-2019, 09:48 PM   #1
2020 25' Flying Cloud
Troy , Alabama
Bathroom mirror opens during travel
Does anyone know a trick to keep our mirror/cabinet door from flipping up and open during travel. We are careful to close it properly before we leave but itís always open after travel.
Chuckash is offline   Reply With Quote
Old 10-14-2019, 12:40 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Add some velcro on the bottom of the cabinet frame. Close and PRESS before travel.
Old 10-14-2019, 05:50 AM   #3
2018 25' International
East Northport , New York
I installed a small latch for travel.Click image for larger version
James
Biker is offline   Reply With Quote
Old 10-14-2019, 07:58 AM   #4
2017 28' International
Baileys Harbor , Wisconsin
I had same problem. Velcro did not work. Tried it. I put another black latch on the bottom. I used a 10lb latch. That solved it for me. No more problems. You can buy 4 at a time on Amazon. Way cheaper. I think about $13 for 4 10lb latches. And you will want a few extra. I had the one i added break on me so I had to replace it. The links is for 8lb. I used 10lb.
https://www.amazon.com/Cabinet-Drawe...NsaWNrPXRydWU=
Daquenzer is offline   Reply With Quote
Old 10-14-2019, 08:50 AM   #5
R2DTube's Avatar
2007 16' Bambi
West Hollywood , California
Images: 11
Our mirror cabinet is plastic, not sure if yours is too? But what I did was I drilled a couple of holes and installed small eye bolts on both top and bottom of the cabinet, and then a small bungee cord attached to both holds the cabinet door closed. Super easy and cheap and it works great for us.
R2DTube is offline   Reply With Quote
Old 10-14-2019, 10:17 AM   #6
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Chuckash.....I don't know how the mirrors are set up on the 2020 25' trailers. Our 2007 25' trailer's mirror has hinges on the top of the mirror and the bottom of the mirror is pulled out to get access to the storage behind the mirror. The mirror originally had one plastic latch on one side to hold it closed. We installed a second latch on the other side of the mirror similar to what Daquenzer suggested, and we never had a problem with it opening while on the road. We also had problems with some of the drawers opening while on the road and we replaced the plastic latches with a similar latch with a higher holding capacity.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-14-2019, 10:29 AM   #7
1958 26' Overlander
tucson , Arizona
Send a message via AIM to Chollabill
Another reason there needs to be a national shrine to bungee cords right alongside the shrine to duct tape. A simple bungee attached to the cabinet and run across the mirror to the other side has kept our mirror secured for 20 years. Chollabill
Chollabill is offline   Reply With Quote
Old 10-14-2019, 11:00 AM   #8
Napa , California
If you are still under warantee, tell the dealer and they will fix it! We had both a pop up mirror and a pop open locker and they increased the size of the locks on both for no charge at all.
Atwebs is offline   Reply With Quote
Old 10-14-2019, 11:18 AM   #9
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Let's take a different approach.
Trying lowering your PSI on your rig.
Mine says on the tire 80psi for max load. I never 'really' had a problem at 80, but learning more about it, I have lowered mine to 70. The rig feels looser to me and i guess it is supposed to be a smoother ride for your rig.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 10-14-2019, 11:29 AM   #10
2019 25' International
Washington , Washington, D.C.
If you have the FB model, then I think you might have the horizontal rectangular mirror that flips up, right? The original clasp is flimsy and during my first warranty appointment, they replaced it with a bigger one which worked for a while. But then I started finding the mirror in up position again after a day of travel, and went back to using duct tape to keep it closed until the next warranty appointment. They put a second strong latch next to the other one and it's stays shut now. It also takes a little more effort to pull open to access shelf behind it..
PatLee is offline   Reply With Quote
Old 10-14-2019, 12:59 PM   #11
Troy , Alabama
We have a 2020 25’ FC FB twin. We have taken a few trips since we got 5 weeks ago. A few small issues, under kitchen sink door hinge failed, the BR mirror , and the deadbolt latch isn’t linining up to lock. I plan tottake it for service ASAP to correct these issues. Otherwise smooth sailing!
Old 10-14-2019, 02:53 PM   #12
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
The service people at our dealership added a latch. It now takes two hands to pull it open, but it doesn't open on the road!
Mike G is offline   Reply With Quote
Old 10-14-2019, 03:08 PM   #13
If you read my previous post this is what I did on my own. It is very easy to do. Cost is minimal. Time is minimal. Don't think you want to take it back to the dealer for this small of a fix. And you want some extra latches around. They will go bad on you after awhile.
Old 10-14-2019, 04:58 PM   #14
2018 28' Flying Cloud
Fairfield , California
I attached a small strap to the bottom, right corner of cabinet door, then a snap to the bottom of cabinet. Only snap during travel, doesn't show, stopped it from flipping up during travel. An above post mentions tire pressure. This issue happened in my first two outings on rough highways when I was running 80 PSI that dealer said was a must. This cabinet door was not the only problem resulting from travel. I now run 55 PSI, get a much better ride, and no more hinges, screws, and rivets popping off. I could probably now do without snapping the strap, but better safe than sorry and it has become habit to snap it.
StuartsDad is offline   Reply With Quote
Old 10-15-2019, 02:18 PM   #15
Oklahoma City , Oklahoma
We just travel with it open. It works for us.
MaryAnnM is offline   Reply With Quote
Old 10-20-2019, 08:01 PM   #16
2019 27' Flying Cloud
COCONUT CREEK , Florida
I like Bikerís fix. Ours is less elegant but it works: 2 x 4-5Ē long pieces of 1Ē Gafferís tape holds it nicely. Just finished 3800 mile trip. No pops. 2019 27í FC FBT.
WBCCI 9602
Cirrusaly is offline   Reply With Quote
Old 11-12-2019, 07:50 AM   #17
on the road , TN
Greetings A quick fix on our FC 2019 rbq for the bathroom mirror was my better half put a new hair tie over the latch for the swing out mirror ! It has not opened since! We in the past used a rubber band in past! But now a new hair tie does the trick!
oldwagon is offline   Reply With Quote
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 04:14 PM
New 27FB bathroom door opens while traveling motozen Interior Restoration Forum 4 11-14-2011 10:17 AM
Drawer Opens During Travel. knunut 2007 Safari 10 10-12-2009 09:46 AM
Mirror Mirror on the wall early General Interior Topics 2 11-20-2005 10:13 PM
Mirror Mirror on the wall.... 05ModPod The Pet Forum 9 03-15-2004 09:42 AM
