Old 08-05-2019, 09:49 AM   #1
2012 25' FB Eddie Bauer
2016 28' Flying Cloud
Point Pleasant , New Jersey
Airstream TV Antenna Omnidirectional
Hi, I have a 2016 28ft AS FC and want to replace the TV Antenna. I removed the top half of the disk and noticed it was factory wired with no connector. Does anyone know if the connector is below the metal base or accessible? Thanks -Mike
mlhomeboy is offline   Reply With Quote
Old 08-05-2019, 09:52 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
There is probably a connector below the base. If not, and it is fed with standard coax you can cut the cable and put a connector on it. The tools and connectors are available at Lowes, Home Depot, and Harbor Freight. I carry a set on my trailer for repairs.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-05-2019, 09:59 AM   #3
The cable is a very thin coax; not something i seen before in any HomeDepot etc. I can only see soldering the wires together at this point. I haven't removed the base yet as I don't want to open Pandora's box.
Old 08-11-2019, 07:37 PM   #4
Silverpuller's Avatar
2018 26' Flying Cloud
Thornton , Colorado
Just curious... What do you want to replace it with?
Silverpuller is offline   Reply With Quote
Old 08-11-2019, 08:09 PM   #5
At TV frequencies, maintaining the impedance of the line is important. cutting and soldering is probably not a good idea.
If you can figure out the brand and model number, Google it. The installation instructions will probably answer your questions.
I'd be surprised if Airstream ran anything other than RG-6 coax up to the antenna. That small flexible stuff is expensive.
Al
S/OS #004
Old 08-11-2019, 08:35 PM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
the thin cable has higher losses that std RG59 cable
you may want to use std cable with vs the small rg6
waninae39 is offline   Reply With Quote
Old 08-11-2019, 09:05 PM   #7
2018 19' Flying Cloud
Coeur d Alene , Idaho
I recently sheared my antenna off accidentally and can confidently tell you that there is no connector down inside the tube or anywhere that I know of. My antenna is salvageable so I'm going to put a connector on the coax remaining in the tube, add a mating connector to the antenna, and reattach the antenna.
I'd be interested in what you plan on replacing it with as this one never has worked very well. It does however do an excellent job of letting you know the garage door isn't all the way up before you shear off the AC.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 08-11-2019, 09:46 PM   #8
RG-6 is newer and better cable than RG-59. It has a slightly larger diameter, not smaller.
https://www.google.com/search?client...&q=rg6+or+rg59
RG-59 would be fine for use with an antenna, but RG-6 would be better. I just use RG-6 for everything since I got a good deal on a 500' box of it.
Edit:
I can't find a manual or specs for the Roadstar but its cousin for the marine environment uses RG-59 which comes with the antenna. Maybe that is what you have. If so you can go to HF, HD or Lowes and get the tools and connectors to cut, strip, and crimp connectors so you can connect the new antenna properly.
Al
S/OS #004
Old 08-11-2019, 09:49 PM   #9
2012 Avenue Coach
Corpus Christi , Texas
Kellogg, way to fess up (and in doing so, save someone else from a lazy garage door.)
rowiebowie is offline   Reply With Quote
Old 08-11-2019, 10:08 PM   #10
Well at least it is good for something.....
Al
S/OS #004
Old 08-12-2019, 03:58 AM   #11
Winegard Rayzor
Old 08-12-2019, 04:34 PM   #12
2018 22' Sport
San Antonio , Texas
Love the self-deprecating sense of humor,
CinTerLine is offline   Reply With Quote
Old 08-12-2019, 05:00 PM   #13
2007 22' International CCD
A good sense of humor is vital, especially as you age...
Old 08-12-2019, 06:12 PM   #14
Winegard Rayzor
+1 for the Rayzar. My 2002 had the original one on it that was not too good for UHF. I bought the Wingman attachment and it works great. Closest TV transmitters to my house are in Orlando 50-60 miles away. I routinely get over 25 channels sitting in my driveway.
Al
S/OS #004
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 07:11 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Compact Roadstar 3000 Omnidirectional Antenna reddog60 Electronics & Connectivity 1 07-29-2012 09:02 PM
Winegard RoadStar Omnidirectional Antenna Minno Audio, Video & TV 18 10-21-2011 04:45 AM
