Old 09-25-2017, 06:01 PM   #1
2016 25' Flying Cloud
Clinton Township , Michigan
Air conditioner fan always runs
My 2016 FC24 air conditoner blows cold air and keeps our unit cold in 90 degree weather, but the fan never turns off although the unit is set on Auto for the fan. Is this normal?
Shelton is offline   Reply With Quote
Old 09-25-2017, 06:24 PM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
The fan will continue to run on Auto until your trailer reaches the set point of the thermostat. If it is really hot outside the AC may not be able to cool your coach to the temperature you have set.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 09-26-2017, 11:31 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
A lot depends on the type of thermostat in your Airsteam. In my Safari setting the control on the air conditioner housing to auto, only cycled the compressor. Not the fan. In my Classic the thermostat on the wall actually shuts down the compressor and fan when the temperature hits set point. It's just a matter of the sophistication of the AC unit and how it's being controlled.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-26-2017, 12:09 PM   #4
dznf0g's Avatar
Oswego , Illinois
Mine is always on when selecting low or high fan speeds. If auto is selected, the fan shuts off with the compressor.
-Rich-
Old 09-26-2017, 12:24 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
On my Classic, the thermostat shuts everything off once you hit temperature on auto. As mentioned above, that may not be true for all models and years. With it in the 90's out in the sun and a single AC operating, my system never would get to a set point in the low 70's. In that case it would just run forever and ever. I bought a magnetic thermometer and keep it on the fridge to monitor what is what in the trailer. Trying to figure out how hot/ cold it actually was from the thermostat ... not so much ....
Old 09-27-2017, 08:28 AM   #6
Thanks all for the replies. I did a system reset on the heating/air conditioner controller. After that every thing worked as I thought it should. Now when the AC is on with a fan setting of auto, it turns off the fan when the temperature inside reaches what I set the temperature at on the thermostat.
Old 09-28-2017, 08:47 AM   #7
Half a Rivet Short
Hi
Glad you found the problem and it didn't involve a trip to the dealer !!!
A year from now somebody will find this thread and say "that's the exact problem I have !!!". I will bet at least a half can of warm beer that their next question will be "how do I perform a system reset?"..... so I'll ask now - how is it done?
A/C fan runs slowly terrencecolp Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-27-2014 09:12 PM
Generator runs air conditioner, no AC current deltatango Classic Motorhomes 4 03-05-2012 11:35 AM
Doh, Only two wires but the fan runs backwards! GREENovaters Electrical - Systems, Generators, Batteries & Solar 8 07-18-2011 05:12 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 05:37 PM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 05:25 AM
