Old 07-10-2017, 11:51 AM   #1
2018 27' Flying Cloud
Aubrey , Texas
Air Conditioner
For you guys that own a 25'-27' with 2 a/c does the a/c keep the trailer at a
reasonable temp (under 80 degrees) in Texas
stujan is offline   Reply With Quote
Old 07-10-2017, 11:59 AM   #2
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
My 25' with one a/c will keep it under 80 degrees. Ain't brought it to Texas yet but that was the case when it was 117 in Nevada and also about 100 in gerorgia which was real nasty.
TravlinMan is offline   Reply With Quote
Old 07-10-2017, 04:11 PM   #3
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
I'm in Bama and often see very hot temps with high humidity. My single 13.5 keeps my trailer very comfortable, can hold 72 on a sunny 95 degree day. My trailer is white which I'm sure helps.
1973Argosy is offline   Reply With Quote
Old 07-24-2017, 04:41 AM   #4
2017 30' Flying Cloud
Tomball , Texas
I had my '18 30 FB in the driveway this weekend (just north of Houston) with temps in the high 90's with a heat index of about 400. Interior was at 70 as the sun came up and by the peak of the afternoon it was about 81 inside according to the thermostat inside temp reading. It didn't feel that warm but it wasn't keeping up. This is on a 30 amp connection with only 1 ac unit running. I'd say go for 2 units just for the extra power to cool the trailer down after a day of travel in the hot sun. If not it will take awhile to get the interior close to comfortable.
Mjacks is offline   Reply With Quote
Old 07-24-2017, 06:29 AM   #5
Traveler
TravlinMan's Avatar
Staunton , Virginia
Well I'll admit it got a lil warmer in the trailer when it hit 118 outside here in Kansas.....
A lil extra ice cream was all it took.
Old 07-26-2017, 06:11 PM   #6
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Angry
I have a 25' FB Classic, we have a hard time getting it cool. Outside 90 inside 79 or 84 I checked out flow air temp at 52 degrees. The fan is on auto but it stays on low, , are open, blow down open, filters clean, only goes to high when I move it to high. Thinking about replacing it with a 15K The elect C/B 20amp 20gaue wiring.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
