Old 08-20-2016, 12:06 PM   #15
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
I connect when needed especially for cold nights. It rides in a battery box in the truck bed or back of the trailer to save tongue weight. When needed, it sits on the ground near the trailer's battery box and plugs in to an Anderson Power connector I added. A sunny day with two 100w Renogy panels on the ground easily recharges all three batteries after a cold night.
Or as an alternative, move to Florida... ��
Way to charge GammaDog!
WBCCI 8653
2015 Ford F-150 3.5 Ecobeast 3.55 Lariat
Old 08-20-2016, 12:56 PM   #16
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
Curious why you didn't just light the oven for warmth. Heats my rig quickly.
Tampatomgirl is offline   Reply With Quote
Old 08-20-2016, 01:18 PM   #17
1996 25' Excella
Tillsonburg , Ontario
With regard to the Smoke alarm going off... I had that happen once when the battery was so low the fan in the furnace couldn't move enough air and the plastic duct hoses overheated. We were woken up by the alarm and could smell hot plastic.
If it happens again check your battery voltage
JCW
JCWDCW is offline   Reply With Quote
Old 08-20-2016, 01:32 PM   #18
Long Island , New York
Select "Heat"
Your owners manual should have all this in it.
Did the dealer walk you through the operation of everything before you took off?
Old 08-20-2016, 02:26 PM   #19
2015 27' FB International
Mary Esther , Florida
39 lets see my temp dosent go past 60 that's long sleeve hoodie stuff in Flordia
Grateful2 is offline   Reply With Quote
Old 08-20-2016, 02:55 PM   #20
2011 30' Flying Cloud
Greenback , Tennessee
Tampatomgirl,
That oven warm up isn't too effective when you oven is a microwave! ;-)
Gneiss Guy is offline   Reply With Quote
Old 08-20-2016, 03:40 PM   #21
Nowhere , Somewhere
Probably for the same reason you don't light the burners for heat.? Or is the oven safe?
1984 Avion 30p 9.1 meter. 2006 Dodge 3500 cummins srw short bed crew cab.
avionstream is offline   Reply With Quote
Old 08-20-2016, 03:53 PM   #22
2007 22' International CCD
Nope. Dumps too much carbon monoxide into the rig. The heater is designed to exhaust deadly fumes outside, assuming it's in good repair.
Never use a cooking appliance for heat.
KE4GNK/AE
Old 08-20-2016, 03:55 PM   #23
Nowhere , Somewhere
That's what I thought, thanks.
Old 08-20-2016, 03:59 PM   #24
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
Been there, done that. The furnace runs the battery to zero in about 1 hour. We were camping when our converter decided to fail and our battery was not recharging fast enough to keep up with the furnace motor despite being connected to shore power. The problem was that it went down to the upper 20's that night. We snuggled down, ran the furnace as long as we could, then crossed our fingers hoping we didn't have frozen water lines in the morning. The trailer stayed cozy and warm enough to get us to morning and we were out of there at sun up.
So - I bought a Camco portable catalytic heater and had an auxiliary connection installed to supply LP to the heater. Not cheap and it is only as a back up but it is ridiculous and dangerous to not have heat just because you don't have electricity. It does not require electric to run and it is safe to use inside. In the short term you can buy the Coleman catalytic heaters that run off the propane cartridges, they last about 4 hours each cartridge. We saw them used at a rally once and the owners said it was enough to keep them warm on nights that went down into the 40's
kdickinson is offline   Reply With Quote
Old 08-20-2016, 04:57 PM   #25
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Careful, the catalytic heaters do use up oxygen in the trailer, so you need good ventilation when using one. Even then I would not sleep with one burning.
Doug and Cheryl
Old 08-20-2016, 05:09 PM   #26
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
A properly functioning stove or oven does not produced carbon monoxide.
It produces carbon dioxide and water vapor .
Oxygen depletion(high co2 ratio) is the danger. Crack a window.
C3H8 + 5O2 = 3CO2 + 4H2O
Al Boondy is offline   Reply With Quote
Old 08-20-2016, 05:12 PM   #27
eubank's Avatar
1967 30' Sovereign
Los Lunas , New Mexico
A decent blanket does wonders. We've already hit 34 here. We sleep with windows in the house open, comfy warm under our down.
Lynn
WBCCI 21043
Old 08-20-2016, 05:18 PM   #28
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Never sleep in your coach without at least 1 window near your head opened slightly along with a roof vent slightly cracked. You get less condensation and it could save your life.
Air conditioner with or without heat pump recommendations Ornstream Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-24-2015 08:49 AM
how can I get a RV fridge to cool in 100 degrees F? nmeyer Refrigerators 15 07-29-2010 08:10 AM
Feel the Fear and Do It Anyway Wardinbb 1959-69 Tradewind 32 10-19-2008 04:48 PM
What's in there anyway... Excella CM LP Gas, Piping, Tanks & Regulators 1 06-16-2007 11:14 PM
Who's club is it anyway???? till WBCCI Forum 53 01-09-2007 09:34 AM
